It is currently Fri Oct 30, 2026 2:33 pm
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Wed Dec 16, 2009 3:58 pm
I would probably advise not to go greater than the 0.8-1mm plug gap. Any 'power' increase is very minimal here as the plug electrode shields the spark anyway. The flame kernal will still travel in the same direction from the spark. The idea of a larger more powerful coil and increasing the plug gap to huge has been around for a while. Just remember the larger the gap the more energy it requires to bridge it. Hence the primary voltage flyback get higher and in return the secondary voltage increases. This puts added stress on the whole ignition electrical system. If the electricity can find an easier way to ground it will. This may be thru the plug leads or the insulation within the coil.
Just some thoughts,
Dan
Vehicle: Jeep
Post Posted: Thu Dec 17, 2009 5:45 am
only the 1 litre and lj's were points and only ones with resistor
Ok, COOL 8) ! :lol:
Well i opened up the gap on my new Bosch plugs, my feeler gauges only went up to 1mm, will get some better ones tomorrow, but so far, the Nippon Coil seems to work well with the 1mm spark gap :wink: :D
Thanks
Vehicle: Jeep
Post Posted: Thu Dec 17, 2009 5:50 am
Just some thoughts,
Dan
Hi Dan,
You make some valid points... i think i will get the GT40 Coil before i open the spark gap further, and will leave it at 1mm and see how it goes...
Post Posted: Thu Dec 17, 2009 12:21 pm
if you need 1.2mm then you ise a 1mm and 0.2mm
glad lots of people are listening to the 700 times I typed GT40 isnt for electronic ignition, do my posts come out in a foreign language or something?
Post Posted: Thu Dec 17, 2009 12:28 pm
Royce, I checked all the coils I could, gathering info, not a real lot out there.
The HEC you speak of, as far as I can work out, are replacements for OEM, no power increase.
Suziblu is gettn a chrissy present, vitara radiator, and MSD
Vehicle: Jeep
Post Posted: Thu Dec 17, 2009 6:32 pm
Yep, what i meant to say is, that my feeler gauges only go up to 1mm in total, that is with all of them used :wink:
Hmmm ok, well i checked out a few online motoring forums, a couple where for Zook, and a couple werent, but, from what i can gather, GT40R are for Points, and GT40 are for Electronic, also the GT40 allow you to open up the spark gap more, as they can handle the extra load... I hear you Royce, but there is conflicting info...
It would be really great if we could have some Factual, Definitive Yes or No Info about Ignition system upgrades and it be put in the Tech section... :wink:
Post Posted: Thu Dec 17, 2009 6:40 pm
The trouble is, trying to get definitive answers, depending on which site you look at, you can get the answer you want.
I had the R to start with, because i was told thats the one for the Suzi, Royce told me thats bullshit, so I put on the GT40 and truly, there was a noticeable feel to her, how much, no idea, but it was easily felt.
I rang Rocket Industries about MSD, and they say that the GT40 is a fine coil for suzis and will complement the MSD ignition, soo, there is more confliction.
Vehicle: Jeep
Post Posted: Thu Dec 17, 2009 11:46 pm
Well i went out and bought a GT40, Oil Filled, High Output coil for $63 !
The guy at Repco kept insisting that i need a GT40R for electronic ignition, but i told him my Zook does NOT have or need a resistor ! he he...
Apparently the GT40R have an internal resistor, didnt know that...
But i had a look on the old Nippon coil, and it says its a 12volt, not 8 or 9volts... so i will see how the GT40 goes, or if it blows up, or damages my electronic points... i hope it doesnt... ( Crossed Fingers, and touch wood )
Post Posted: Thu Dec 17, 2009 11:54 pm
Excellent, let us know how she goes with the new coil.
And, what gap you do.
Vehicle: Jeep
Post Posted: Fri Dec 18, 2009 5:54 am
I hope it is excellent ! :wink:
I have left my gap at 1mm for now, and will see how it goes for a while :wink:
Vehicle: Jeep
Post Posted: Fri Dec 18, 2009 6:40 am
:( Its 11pm here on the West Coast, and i just went outside to move my Zook of the lawn and into the garage, and... it took me a good 2 mins of cranking before i could even get my Zook to fire, and when it did, it sounded like it was running on 2 cyl, it took another 30 secs of pushing the gas pedal to keep it going long enough to idle, then it finally calmed down and began firing on all 4 cyl and idled ok, and then revved ok :cry: :cry: :cry:
Sooo... if this is what the GT40 Coil does for my Zook, then i am not impressed at all with it...
My Nippon coil would start my zook after just a few secs or less, even with the bigger spark gap... Not Happy Jan ! :cry:
So now i am going to have to put my old Nippon Coil back on in the morning, as i am out and about on Sat clocking up a few kms, its 90km to Perth from where i am, and i want it to run reliably !
Anybody in Perth want a GT40 coil ? :wink:
Post Posted: Fri Dec 18, 2009 7:46 am
Its not a moisture problem is it.
Post Posted: Fri Dec 18, 2009 12:21 pm
lols :)
R doest not mean it has an internal resistor
Vehicle: Jeep
Post Posted: Fri Dec 18, 2009 9:14 pm
Well iput the old Nippon Coil back on this morning, and its purring like a kitten ! :wink:
Repco didnt want to give me my money back because it is an electrical item, and i could have damaged it, phhhht... i told them i can check the coil resistance if they would like, so they said oh, we will make an exception this time... :rofl:
SuziBlu - Nope no moisture... i really wanted this coil to work... :(
Royce - No gloating, No i Told You So ?!?! :goodjob:
peaceout
Post Posted: Fri Dec 18, 2009 9:23 pm
GT40 suits points vehicle without a ballast resistor, GR40R suits points vehicle with a ballast resistor. I'm sorry but I would not have given anyone there money back, It is now a used part.. and electrical. You my friend have been very lucky to get anything back. I will not take any electrical component back unless the packaging is unopened..
Post Posted: Fri Dec 18, 2009 9:48 pm
the repco dude was also trying to sell him a coil that was even more wrong as well :wink:
Vehicle: Jeep
Post Posted: Fri Dec 18, 2009 10:29 pm
Well its probably a good thing i didnt buy it from you :rofl: peaceout
How else am i gonna know if it works, unless i connect it up to my car and try it :roll: is used for 5 mins still used, its still new to me :roll:
I understand that Repco were under no obligation to refund my money, i wasnt going to force the issue with them, i was just gonna sell it on ebay if they didnt refund my money, its not as if i was a one time customer, i go in there a fair bit... anyway, i agree i was lucky to get my money back... :wink:
peaceout :cheers:
Post Posted: Fri Dec 18, 2009 11:31 pm
Its all good, dont sell aftermarket bits anymore anyway. I must admit that I was to lazy to read the earlier pages of this thread but I did see that royce had pointed out that this coil would not work in your application and therefor was of no use to you. But you tried it anyway. I know that the guy that sold it to you should have told you this aswell.. If you bought a tooth brush, opened the packet and brushed your teeth for 5 min, decided that you dont like it because it is too soft so you put it back in the packet and took it back. Would you expect a refund? would you like to be the person whom purchased it after somone else had used it? :wink: Sorry to be so perdantic but after years of having people bring parts back because they thought that it was the problem and it turned out to be something different, you want to educate others about what you have to go through every day.
I hope that didn't come off too strong, it wasn't a direct dig at you. Just pointing out the facts from the other side of the counter...
Post Posted: Fri Dec 18, 2009 11:34 pm
However, if the guy behind the counter says "this is the part for your car" and it doesn't work, you have every right to take it back for a refund...
Post Posted: Fri Dec 18, 2009 11:47 pm
well thats got me fucked, my toy is going much stronger and holds revs much better. Your will not even idle, hmmmm.
Post Posted: Sat Dec 19, 2009 12:15 am
Providing that you have given the parts guy the correct information of course :wink:
Why do you think parts guys ask so many questions and dont like it when you answer "it dosent matter, they are all the same" A few months ago there was a discussion about 1.3l sierra clutches on here. Most people will tell you that they are all the same, yet clutch industries (ex pbr clutch) list 3 different clutches. Why? it is because over the years they have found that there are variences thoughout the models. Hell, mitsubishi can have different parts from month to month of build... and then revert back :?
But as the installer YOU ultimatly bare the responsibility to make sure you have been supplied with the correct parts BEFORE you fit them. ie; no mechanic should fit a clutch to a car and later on when they cant get the box back in or go to take off and find that there is no drive only blame the parts dude because he should have made sure that the clutch plates spline was correct before fitting it to the car.
It can get very difficult and sometimes you need to look at a problem before you can make a final decision...
Post Posted: Sat Dec 19, 2009 2:40 am
All good and true, but you have people on here, me, saying, that it is a great idea, from personal findings.
I stand by my statements, the GT40 I put on my 1.3l zook is a great upgrade, works wonders.
Because of my saying how good an upgrade they are, 2 of my friends have done the same, and also say how great they are.
Vehicle: Jeep
Post Posted: Sat Dec 19, 2009 5:41 am
Yep i had GT40 Coils on ALL my Holdens, they worked well !
Ahhh a 1.3L Sierra, they may like the GT40, but my 89 Vitara G16A engine did not like the GT40 one bit, it just said :no: :gross:
Oh well, we live and learn through experience and failure, and i learnt what my Zook ignition doesnt like now... :wink:
peaceout
Post Posted: Sat Dec 19, 2009 11:27 am
Mate put a GT40 on his vitara, same deal, is stoked.
Post Posted: Sat Dec 19, 2009 1:11 pm
Old Holdens would be GT40R :)
I would like the wrong info in this thread to stop for the sake of people searching in the future, whether it works for you or not GT40 of any kind is wrong for any electronic ignition Suzuki
Post Posted: Sat Dec 19, 2009 1:44 pm
http://www.procarcare.com/icarumba/reso ... nition.asp
Vehicle: 1995 Sierra 1.3
Post Posted: Sat Dec 19, 2009 3:44 pm
Perhaps a list of coils that will work for each model Suzuki. Also a warning in this threads title about GT40's.
Even though it has worked on SuziBlu's, it hasn't worked on MacBear's. I can see Royce's concern… Someone may not read the whole thread, jump the gun and go out a buy a coil that will not work correctly in their vehicle.
Vehicle: Jeep
Post Posted: Sat Dec 19, 2009 4:30 pm
Yes you are right, my old Holdens had the GT40R...
Maybe if you could put a proper answer to the GT40 question in the Tech section, something like " GT40 Coil Yes or No ", as i think thats where people will go to first... :wink:
:cheers:
Vehicle: Jeep
Post Posted: Sat Dec 19, 2009 4:34 pm
SuziBlu wrote:
http://www.procarcare.com/icarumba/resourcecenter/encyclopedia/icar_resourcecenter_encyclopedia_ignition.asp
Thanks for the link, some good info there ! :wink:
:cheers:
Post Posted: Sat Dec 19, 2009 4:35 pm
I trully don't understand, I believe the coil was faulty.
Users browsing this forum: Google [Bot], Zook_Fan and 390 guests
