It is currently Fri Oct 23, 2026 7:51 am
Post Posted: Wed Dec 30, 2009 3:25 am
every time i turn the egnition on i have to tune my stereo i tested the memory wire with a circuit tester and there is only a tiny bit off glow from the bulb compared to the others. any input would be appreciated....
Post Posted: Wed Dec 30, 2009 3:30 am
blown fuse
bad connection
do you have a circuit tester ?
Post Posted: Wed Dec 30, 2009 3:35 am
he has a circuit tester...
run a wire to your battery or a known good source of power to the memory wire & see if it hold the programs. if it does you know your head unit is working properly & it's the constant power wire is the problem, search for another constant power wire that has good power & connect the memory wire into that...
while you are playing under the dash, check all your earths are on bare metal & they are tight!!!
Vehicle: jimny
Post Posted: Wed Dec 30, 2009 11:15 am
buy yourself a multimeter. I think you can get a digital unit for under 20 bucks. Then check your source wire for voltage. If its below 12volts find another. Its really a simple fix.
Post Posted: Wed Dec 30, 2009 1:45 pm
check your fuses and check how good the connection is, otherwise you can find a constant power wire from the clock that is suitable for the memory wire on the stereo
Post Posted: Thu Dec 31, 2009 1:14 am
hellalujah it works thanks fellas....
Post Posted: Thu Dec 31, 2009 1:19 am
and the problem was?
Post Posted: Fri Jan 01, 2010 9:16 pm
bad connection i pulled it out tested it and it worked, do i did it all back up and it works
Post Posted: Fri Jan 01, 2010 9:19 pm
did you solder all joins... ??
twist & tape method only works if you are employed by smashfields or wogbarn
Post Posted: Sun Jan 03, 2010 10:05 pm
yea soldered em all.
Users browsing this forum: No registered users and 133 guests
