It is currently Sat Oct 24, 2026 3:48 am
Post Posted: Thu Dec 31, 2009 1:49 pm
Can someone please tell me what the 16v EFI alternator is rated at :?:
Post Posted: Thu Dec 31, 2009 2:39 pm
I'm pretty sure it's 55 amps. I can check mine later if no one else chimes in.
Post Posted: Thu Dec 31, 2009 2:55 pm
yep 55amps
Post Posted: Thu Dec 31, 2009 3:27 pm
Thanx gentlemen, I need something bigger for Dual battery setup.
growing old is nature, growing up is choice.
Post Posted: Thu Dec 31, 2009 3:30 pm
while the 120 amp Ford alternator is an easy and useful swap, what makes you think you need a bigger alternator just for 2 batteries
Post Posted: Thu Dec 31, 2009 4:23 pm
Bothbatteries are over 80 Ah and will be used to run fridge lights etc while camping I would rather not have to spend 2 plus hours of engine running while waiting for the batteries to reach their full potential
Post Posted: Thu Dec 31, 2009 5:06 pm
EF Falcon/Fairmont 110AMP is an easy fit and cheaper than Suzuki..
Make sure you get the Mitsubishi alt off the six cylinder not the Bosch item off a V8.
Post Posted: Thu Dec 31, 2009 9:08 pm
what charge rate can your batteries take though?
Mine charge no faster with the bigger alt than the stock one, they are better when you want to run a heap of lights as well as recharge though
Vehicle: 92 Suzuki Sierra
Post Posted: Thu Dec 31, 2009 9:27 pm
.... some might be 60a.
I bought a jimny alternator and the guys upgrades it cause it was only 75a . Funny thing is the manual says its 60 (maybe he tested it or just assumed the first 3 spots of the part number was the rating)
-Santos
Post Posted: Thu Dec 31, 2009 10:15 pm
If you work out the amp load out as you are driving with lights heater wipers etc you might find that there is only about 10 Ah to charge batteries, so if youhave a fridge phone charger satnav etc you could find you are in the minus and end up with flat batteries.
Users browsing this forum: Google [Bot] and 121 guests
