It is currently Sun Oct 25, 2026 3:11 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2
Vehicle: SJ80
Post Posted: Wed Dec 30, 2009 2:50 am
Bucket wrote:
I ended up buying a 12" 1300w Sony Explod including the box for 50$. It's a 380RMS sub, and i'm using my 4chan amp. I've bridged ch1 and ch2 for a total of 280RMS so thats good enough for me.
Only thing I was gunna do was run ch3 for a left 6x9 and ch4 for the right one and set it on a HFP. Only prob is my headunit doesn't have another 2 RCA slots to run ch3 and 4 :(
The amp should only have one set of rca plugs for input so you only need the one line coming from the head unit. So ch3 & 4 recieve the same signal as 1 & 2. Plug the speakers in, they should work.
Vehicle: SJ50 hardtop!
Post Posted: Wed Dec 30, 2009 4:38 am
I thought that would be the case but i couldnt get any sound out of the 6x9s and I tried different settings and nothing. It worked when i switch the RCA plugs into the other two amp inputs.
I'll have another play in the morning.
NT SJ50
Post Posted: Thu Dec 31, 2009 4:41 am
Figured it out after giving a mate a call it and was pretty obvious. Need a headunit with the second set of RCA out.
Oh, and I think my amp might be really dodge, because my subs already gone funny.
NT SJ50
Post Posted: Fri Jan 01, 2010 3:14 am
yer i think ur amp might be dodgy as i had no troubles when i had my 4 channel amp running them off 1 rca line
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Fri Jan 01, 2010 3:52 pm
you can buy RCA splitters.. not that expensive, you get them from autobarn, super dear, REPCO etc
have used them heaps of times in systems that i have had. haven't had any problems with them
Post Posted: Sat Jan 02, 2010 7:26 pm
When I turn my gain up or increase the LFP DB boost from 0->6 or 0->12, my sub just pops in and out and my whole system pumps this low "woomp" sound. I think my amps fucked.
NT SJ50
Post Posted: Sun Jan 03, 2010 1:21 am
it could also be the quality of ur rca leads and wiring
check those aswell as ur amp
-indebt 4x4 club-
Post Posted: Sun Jan 03, 2010 3:02 am
I went over my wiring a few times and it's all very strong.
I tried plugging my 6x9s into it and the same thing happens to them when I turn up the gain. Ah well, stupid cheap powervox
NT SJ50
Post Posted: Sun Jan 03, 2010 10:34 pm
my powervoxs work fine for me
pumps my subs nicely
-indebt 4x4 club-
Post Posted: Sun Jan 03, 2010 11:09 pm
motorboating its called, your wirings shit
gain is for level setting, its not a volume control!!!!
Post Posted: Mon Jan 04, 2010 2:49 am
if u turn ur gain up to far u will blow ur amp and possibly ur subs
-indebt 4x4 club-
Users browsing this forum: Google [Bot] and 254 guests
