It is currently Fri Oct 23, 2026 9:26 pm
Post Posted: Fri Jan 01, 2010 9:51 pm
hey im way sorry if this subject has been covered a billion times, but my sierra was running sweet and really reliable but now now it starts and runs for 5 seconds and then dies. i went mud driving not long ago so i degreased the carby so now it runs for a while then dies, i sprayed a heap of carby cleaner down the throttle body. I went to start it and it happened pretty much straight away and now it won't stop... could it be electrical? it's a standard G13A. it was showing no symptoms before it's a all of the sudden thing...
it's a little worrying as i need it for work....
Post Posted: Fri Jan 01, 2010 9:54 pm
give it a good rev with the air cleaner duct off the carby and choke it with your hand a couple of times always seems to work for me
Vehicle: 75 Cruiser
Post Posted: Fri Jan 01, 2010 9:56 pm
Have you tried the 1 and 4 lead swap backfire pop procedure?
nope tried that.... cheers anyway :D
Vehicle: jimny
Post Posted: Fri Jan 01, 2010 10:24 pm
sounds like a jet blockage issue josh, try some compressed air or start to pull the carbie off it mate.
probably something is floating around and blocking the jet, try running it with the choke on, if it runs then you would guess that the jet is blocked...
hope i made sense
Post Posted: Fri Jan 01, 2010 10:36 pm
Yep the old 1 too 4 lead swap over does a back yard fix.
Post Posted: Fri Jan 01, 2010 10:47 pm
Or 2 to 3, only problem with that is you leave the shit in the carb, zookster's method suck's it out of the carb & the eng turn's it into ozone killer. :twisted:
Post Posted: Sat Jan 02, 2010 6:55 am
Mine does the same thing but only on the first start up after it has sat long enough to cool all the way down.
I will try all these suggested quick fix thank you as I was going ot ask the same thing if it haddent stopped.
The hand choke thing I am guessing that creates more vacume on the fuel/ventura sucking through the small blockages???? This could make the problem much worst couldn't it?? if it blocks the jet completely???
Post Posted: Sat Jan 02, 2010 11:27 am
do you know if it's overfuelling or underfuelling?? As already mentioned it could be just a blockage and I'd use either the back firing method or the rag over the top of the carby to try and get the crap out of it. If it's overfuelling you may find the the needle and seat in the carby is sticky. Give it a light tap around the needle and seat area with a hammer to see if it comes good. Otherwise it sounds like carby rebuild time
Post Posted: Sat Jan 02, 2010 8:47 pm
hey i went to sydney for yesterday and today so i havn't have a chance to look at these.
Thanks so much for all your replys, i tryed to blow it back and it did work for about 4seconds then died, then started and went to 3grand (and stayed there) so at a guess i've got rubbish in the bottom of my bowl.
cheers :D
Post Posted: Sat Jan 02, 2010 9:16 pm
I used a great product from ThreeBond called Engine Conditioner. It's a foam you spray down the throat to clean it out. It cured my random stalling problem. I'll be using it on the Prado when I get a chance...
Post Posted: Sun Jan 03, 2010 12:10 am
How long has this been on the market?
Same as scuby cleaner??
Post Posted: Sun Jan 03, 2010 12:15 am
Not sure, I think it is fairly new?
Post Posted: Sun Jan 03, 2010 12:22 am
How much to purchase this kind of product from YOU :wink:
Post Posted: Sun Jan 03, 2010 1:01 am
I don't think it is very expensive, I'll find out
Post Posted: Sun Jan 03, 2010 1:29 pm
hmm, i think it ill find all the sprays and now pull apart cleaning methods before i go for it... hmm what will be open today...
Post Posted: Sun Jan 03, 2010 4:55 pm
woo hoo, pulled it all apart and cleaned out the primary and secondary jets and all lines, and now it runs sweet 8)
A BIG THANKS FELLAS :D
Users browsing this forum: Beery and 246 guests
