It is currently Mon Oct 26, 2026 12:01 am
Post Posted: Thu Jan 07, 2010 4:13 pm
Just looking for some pics on other's 1.6 airbox setups in the sierra. Im upto that stage and need some inspiration :D
Dan
Post Posted: Thu Jan 07, 2010 4:35 pm
Crude but effective...
Post Posted: Thu Jan 07, 2010 4:40 pm
same set up as mine works well, would b good to get rid of the the afm on them the cone thing is weird
Post Posted: Thu Jan 07, 2010 5:02 pm
Hey want33s I am guessing the 4 little fuel filters are your breathers???
Post Posted: Thu Jan 07, 2010 5:22 pm
no dave he has a lot of dirty fuel where he lives :wink:
Post Posted: Thu Jan 07, 2010 5:53 pm
I wanted to know what it is he has it conected to? I have mine almost exactly the same but coming up the other side and they are all pointing down to help not get any water in them. It looks like his are almost capped off.
Vehicle: Suzuki
Post Posted: Thu Jan 07, 2010 7:15 pm
looks like he has stuck the ends into a bit of hose ;)
Post Posted: Thu Jan 07, 2010 7:28 pm
Definitely diff/transfer breathers.
Post Posted: Thu Jan 07, 2010 9:07 pm
Yeah they are diff/transfer/gearbox breathers.
I put the bit of hose over the top just to stop mud/dust falling directly into filter.
Vehicle: SJ80
Post Posted: Thu Jan 07, 2010 9:15 pm
I am using one of those wanky pod style filters instead of the stock air box as a temporary set up until I get around to putting the airbox in. It has been temporary for a year now! I will get to it eventually as I'd like to run a snorkel so I'll be keeping an eye on this thread for ideas.
Post Posted: Thu Jan 07, 2010 9:30 pm
Whats wrong with the afm? Youd b going backwards pulling it off. It will run, but like shit.
Vehicle: jimny
Post Posted: Thu Jan 07, 2010 10:20 pm
see if you can have a look in zookers rig thread on his green lwb, well that is if he has a buildup thread, it looks factory
Post Posted: Fri Jan 08, 2010 12:02 am
Unifilter.
Going to make an airbox around it soon, with a snorkle coming out of the passengers side cowel panel and into the engine bay through the firewall.
Post Posted: Fri Jan 08, 2010 12:03 am
I have the same set up as jas. I am looking for ideas to run a snorkel though.
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Post Posted: Fri Jan 08, 2010 3:57 am
This is what i made up. I found the airbox at the wreckers, not sure what its out of, but it was 100% steel so i could mod it easily, plus it takes a commodore sized panel filter, nice n cheep.
Post Posted: Fri Jan 08, 2010 4:08 am
Hmmm, the Baleno manifold is SOOOOOOOOO much better than the vitara one :(
Post Posted: Fri Jan 08, 2010 9:53 pm
i would not go that far. the vitara manifold allows a virtualy straight intake, the jimny (which i think is in pj-zooks pic) will need some serious bends.
here's mine.
Post Posted: Sat Jan 09, 2010 2:29 am
that looks like its outy of a pintara takes a A360 filter
 Profile YIM
Post Posted: Tue Jan 12, 2010 4:02 pm
mines sorta like joes but not as flash :lol:
Mine had the 90* bend so i cut it off and just have it running in a straight line now
Imagecouple of bits of flat bar mount it to inner guard.
then i ran a snorkel out of it through the bonnet,its not flash in any way(hopefully soon ill make a exhaust tube one)worst thing about it is i cant have a 2nd battery up in the far corner now due to air box and flexi hose :cry: Image
Post Posted: Tue Jan 12, 2010 10:03 pm
Joebloe my donk is Baleno, not Jimny, got me 300cc more than that lol
Post Posted: Wed Jan 13, 2010 12:29 am
not talking about donks, is reference to the intake manifolds. you have the same as jimny.
Post Posted: Wed Jan 13, 2010 12:56 am
I intend swaping the baleno box for the 1ltr airbox in the future
The baleno intake doesnt leave much room for brakes, lucky im not boosted.
Post Posted: Wed Jan 13, 2010 4:25 am
Thanks for the pics and ideas guys! Keep em coming. Think I have just finalised my setup. Will throw some pics up soon. Ive noticed that most of you seem to have a body lift that no doubt will give you wayyy more space to play with. Ive managed to squeeze the 16v in without a body lift which is making a neat airbox setup not a easy task.
Dan
Post Posted: Wed Jan 13, 2010 4:33 am
Yeah it does.
Just shift the motor 10 mm to left and rotate engine 2-3degrees to left also. This will allow space for a GTI booster and master cyl, which should bolt onto your firewall.
Peter
Post Posted: Sat Jan 23, 2010 3:27 am
Ok after alot of hummin and harrin' this is what ive come up with. Uses all the piping from the 1.6 and 1.3 airbox setups and retains the original 1.3 box. The only additional piece i needed to purchase was the blue reducer. Clears the bonnet but quite a bit+I also dont run a body lift in this one.
Dan
Post Posted: Tue Jan 26, 2010 7:52 pm
I have just changed mine. It used to be right up against the slam panel but I have moved it back so I can use a shorter flexi pipe to the rest of the intake, and so that I can put the overflow bottle back in it's stock location.
If I move the charcoal canister I should be able to fit a 2nd battery in there if I want to. I do have to relocate my washer bottle though.
Because of the odd shape of the Vit airbox it's hard to get it to mount properly in the Sierra. This is how i picked up one of the mounts, it works really well.
That's just some M6 threaded rod cut to size, nuts to suit and some large dia. panel washers.
On the opposie corner I picked up one of the original washer bottle mounts with a small bracket made from flatbar.
Note my guard chop for virtual lift in the background :lol:
Post Posted: Tue Jan 26, 2010 9:17 pm
hmmm... geez dont you guys have dirt or mud in your states, those engine bays look a little to clean for my liking
Post Posted: Tue Jan 26, 2010 11:43 pm
if theres one think i hate its a dirty engine bay.My cars are always way too clean underneath considering the driving they do.
JrZook that looks awesome mate,such a tidy job on your whole car 8)
Users browsing this forum: Google [Bot] and 99 guests
