It is currently Fri Apr 24, 2026 12:36 pm
Post new topic Reply to topic  [ 82 posts ]  Go to page 1, 2, 3  Next
Post Posted: Mon Aug 24, 2009 1:25 am
ITEM:
Body Lifts
a) Sierra SWB
b) Sierra LWB
c) Vitara SWB
d) Vitara LWB
e) Jimny
Transfer Lift Mount Kits
f) Sierra (all 1.3lts, not 1.0lts. Standard height kits are fine.)
CONDITION:
new
PRICE AND PRICE CONDITIONS:
a) $210
b) $250
c) $235
d) $250
e) $235
f) $120
All include postage
EXTRA INFO:
Body Lifts are Poly Blocks
Transfer Lift requires drilling of chassis
Brisbane
CONTACT:
greg.dds@internode.on.net
PICTURES:
a) Sierra SWB
d) Vitara LWB
e) Jimny
f) Sierra Transfer Lift Kit
Post Posted: Mon Aug 24, 2009 2:51 am
I have had these fitted in Casper for over 4 months now and have no problems at all. I also have a set on Std mounts fitted to my Stock Sierra and again not a problem.
The lifted ones works out that the T/case is now sitting above the chassis rails.
Thanks Greg for making Casper (and my stocka) the dummies for testing.
Post Posted: Mon Aug 24, 2009 3:21 am
why do you have to drill the chassis?
Post Posted: Mon Aug 24, 2009 7:10 am
I'm confused to why is the transfer case lift kits are made of 4 separate parts then washers as well
6 layers :?
Vehicle: 1999 Jimny
Post Posted: Mon Aug 24, 2009 9:50 am
6 layers :?
something like: washer,rubber, chassis, rubber, T/case mount, rubber, chassis, rubber washer. at a guess I'd say that'd be it........... been wrong before though............lots :P
Good looking kits by the way. Silly question time.. Do you do a standard kit for a LWB??? I need a complete body mounting kit for mine.
Post Posted: Mon Aug 24, 2009 1:10 pm
Twitchy is correct, to provide total insulation there is a block on both sides of the transfer mounts and chassis mount. The reason for the two blocks is to allow for different heights to be available.
A steel crush tube runs through the whole assembly, to provide insulation from this tube to the chassis and transfer arms a larger hole needs to be drilled.
Post Posted: Mon Aug 24, 2009 1:12 pm
Do you mean body lift or the standard body mounting rubbers, I have these as well.
Vehicle: 1999 Jimny
Post Posted: Mon Aug 24, 2009 9:49 pm
Will put the Corolla body on this weekend, then I will know what I need in the way of standard or lifted.
Post Posted: Mon Aug 24, 2009 11:31 pm
will the t case lift fit with out a body lift? if so pm me some details and i'll get some money to you.
Post Posted: Tue Aug 25, 2009 12:10 am
No, there's bugger all room in there from standard. Doubt you would even get 12mm of lift without an issue.
Post Posted: Tue Aug 25, 2009 12:29 am
I have a standard New T/case setup on my other stock Drover.
They work well as well guys.
Look the same as the lifted ones, but smaller if that makes sence.
So if you want to upgrade the standard t/case mounts, these are the way to go.
Post Posted: Sat Sep 05, 2009 6:08 pm
hay mate can ya do a fuel tank lift as well?
Post Posted: Sat Sep 05, 2009 6:21 pm
i am interested, but why do u have to drill the chassis for the tcase lift?
Post Posted: Sat Sep 05, 2009 6:56 pm
What???
Post Posted: Sun Sep 06, 2009 11:55 pm
Will you be doing Gv kit`s in the near future? or can the vit kit be made to fit??
Post Posted: Sun Sep 06, 2009 11:58 pm
What???
i keep smashing fuel tanks so if i have a 50mm body lift a of the shelf kit to lift the fuel tank would be a good thing. :wink:
Post Posted: Mon Sep 07, 2009 12:11 am
put it on top of the rail`s.
Post Posted: Mon Sep 07, 2009 12:43 am
What???
Lifting the tank is as easy as cutting the mounts and rewelding them.... BUT.... lifting the tank puts the filler pipe in the middle of the chassis rail..... Last time I tried petrol didn't flow through 2mm steel :wink:
To get around the filler problem you'd either have to lift the tank about 120mm which means raising the rear floor or move the filler inlet to the top of the tank(which any radiator shop/BALL should be able to handle)
Vehicle: SJ50 hardtop!
Post Posted: Fri Jan 08, 2010 7:10 pm
I'm interested in a 2" BL for a 95 Vitara SWB.
Messaged you on 4wdaction, but if you can, can you reply to me here thanks.
Cheers,
Alex
NT SJ50
Post Posted: Fri Jan 08, 2010 11:32 pm
Alex, you have a PM
Post Posted: Mon Jan 11, 2010 5:28 pm
Do u need to lift your transfer case if your doing a body lift? If so why?
Post Posted: Mon Jan 11, 2010 6:14 pm
No you don't. You can lift the transfer after the body lift is fitted but it's not essential. Lifting the transfer just gives you more clearance and protects the transfer from possible impact.
Post Posted: Thu Jan 28, 2010 3:38 am
You have a PM 8)
Vehicle: 4wd
Post Posted: Wed Mar 17, 2010 12:41 am
got any instock?
Watch out or you'll get sued.
Post Posted: Wed Mar 17, 2010 1:20 am
He always has them in stock. :wink:
Post Posted: Thu Mar 18, 2010 1:10 am
email sent.. and now cash :D cheers mate.
Sam
Post Posted: Thu Mar 18, 2010 1:49 am
How much will it bee without postage? I can pick up. How long will it take to install these?
Post Posted: Thu Mar 18, 2010 11:43 am
How does the 2 inch transfer case afect the tailshaft angles? Will a tailshaft spacer be needed?
Does anyone have a pic of the tailshaft angles?
cheers
Hutch
255 characters
Post Posted: Thu Mar 18, 2010 5:21 pm
Yes you can pick it up, allow 3 hours to install. Yes I have stock.
Hutch, normally a 40mm kit works well with a transfer with a roctoy ring, Casper and NFI both have them and had no issue with driveline angles. I do have a spacer on the front but that's mainly for the RUF rather then the trasfer lift.
Post Posted: Thu Mar 18, 2010 8:46 pm
Mine runs the lifted transfer with no spacers, no problems yet
