It is currently Sun Oct 25, 2026 2:50 am
Post Posted: Fri Jan 29, 2010 9:07 pm
:? Can anyone out there help, I am about to fit an aftermarket tacho as my dash one seems to have a mind of its own at times. I thought seeing as I have one laying around I might as well fit it, is there any idiosyncracies with 1.3 sierras ignition that I should be aware of. :shocked:
Post Posted: Fri Jan 29, 2010 9:40 pm
its dead easy 4 wires, earth, accessories, power/light? and signal which comes of one side of the coil.
Vehicle: WR250F/Jeep XJ
Post Posted: Sat Jan 30, 2010 12:42 am
Yeah I had to find my tacho wire the other day. From memory its the black with orange or red trace that goes into the coil.
Post Posted: Sat Jan 30, 2010 1:10 am
thank you gentlefolk I was sure that it would not be too difficult but b etter to be thought a fool than go ahead stuff it up and prove it with out doubt :roll: :)
Post Posted: Sat Jan 30, 2010 1:53 am
if you want to mate you can pick up all you need off the back of the dash cluster.. saves running wires everywhere.
Post Posted: Sat Jan 30, 2010 1:59 am
thats what I did with mine, and its all apples.
just broke out the old test light and pulled the plug on the back
of the cluster and tested each wire when I turned on my parkers
etc. pretty straight forward.
Users browsing this forum: No registered users and 248 guests
