It is currently Mon Jul 27, 2026 5:10 pm
Post Posted: Fri Feb 12, 2010 12:32 am
What is the best way to swap them back
Post Posted: Fri Feb 12, 2010 12:35 am
Its just a matter of taking the extended out and putting the stock ones in.
15 minute job to do both sides. Only 4 bolts.
Post Posted: Fri Feb 12, 2010 12:36 am
Remove the bolts through the springs at the shackle end, drop the end of the spring to the floor, remove the bolts holding the shackle to the chassis, bolt the stock shackle to the chassis, bring the spings back up and bolt into the shackle.
Easy. :)
I want my old sig back :(
Post Posted: Fri Feb 12, 2010 12:58 am
Easy. :)
thank you
Post Posted: Fri Feb 12, 2010 1:02 am
hopefully it does only take 15min i remember when SI3RR4 and i changed his springs, sometimes those damn bolts just dont want to budge. but yes fairly simple procedure
Post Posted: Fri Feb 12, 2010 1:10 am
A highlift makes this a very easy job because you can get the car just in the right spot so there is no load on the shackles at all. then everything slides apart real nice.
Post Posted: Fri Feb 12, 2010 1:14 am
Doing both sides at the same time helps as well. Take both drivers and Pass. side extended shackles off and then put the stock ones back on.
Post Posted: Fri Feb 12, 2010 1:17 am
But you have to hit some thing with a hammer, just cause it make's you feel tough & in control. :P
P.s. Easy job
Post Posted: Fri Feb 12, 2010 1:24 am
Im always tough and in control, i dont need to hit things with a hammer to get that feeling.
Post Posted: Fri Feb 12, 2010 1:25 am
its amazing how good you feel after hitting something.
Post Posted: Fri Feb 12, 2010 1:30 am
haha this comment could easily be takin out of context if u have a disturbed mind such as mine . . . ps definalty do both at same and use jacks, takes all tension off shackles
Post Posted: Fri Feb 12, 2010 6:51 am
I dont know about you Al but i feel fantastic.
Users browsing this forum: No registered users and 322 guests
