| Author |
Message |
tanshi
 Posted: Fri Feb 12, 2010 5:25 pm |
After a set of 1 litre cv's to do a disk brake swap on an LJ50
zookster666
 Posted: Fri Feb 12, 2010 5:36 pm |
Got a complete front diff here only need rotors and calipers pm me if your keen
tanshi
 Posted: Fri Feb 12, 2010 5:47 pm |
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Fri Feb 12, 2010 8:27 pm |
You can run 1.3 CV's if you fit them to your 1.0 axle.
tanshi
 Posted: Fri Feb 12, 2010 8:33 pm |
im pretty sure they are a different length, and so can only use 1 litre cvs
you can use 1.3 cvs but i think you need custom made inner axle shafts
want33s
 Posted: Fri Feb 12, 2010 11:46 pm |
tanshi wrote: im pretty sure they are a different length, and so can only use 1 litre cvs
PM Christover.. He did it in Frog.
ca18zook
Joined: Sat Jan 19, 2008 10:30 pm Posts: 156 Location: Ipswich
 Posted: Sat Feb 13, 2010 3:34 am |
the 1.3 and 1 liters also have different splines
If there is a way to run 1.3 cv in 1L diffs please share the info.
Trent
_________________ Drive it like u stole it!!!
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Sat Feb 13, 2010 5:44 am |
Unlike Sierra's LJ50 and LJ80 have equal length front axles and drum brakes. A Suzuki front axle is two pieces, a long end that goes to the diff and a short end that goes to the hub, they are joined by a cv joint made up of a cup like outer race, ball bearings and a bearing cage that has an inner race that has a splined centre
The long end of the axle is splined both ends, one spline for the diff centre and the other for the cv, the cv spline has a round wire spring circlips so the the axle spline can be pushed into the cv bearing carrier spline and lock into place. Fortunately the cv spline on an LJ and a 1 litre is the same which allows you to do disc brake and free wheeling hub upgrades to your LJ fairly easily.
For the upgrade you use an LJ axle and a 1 litre axle and make one from the two, you seperate both axles at the cv's and then fit a LJ inner axle to a 1 litre outer axle. You cannot reuse the LJ swivel housing as it is different and will not accept the sierra discs etc, you can use either a 1 litre or a 1300 swivel head, disc, caliper and fwh.
You cannot use a 1300 axle for the upgrade because the spline in the cv is different to 1 litre and LJ so the two parts of the axle cannot be combined.
This bit is hard to describe but here goes - some 1 litre axles are very difficult to get apart because on some of them the circlips that holds the axle into the cv is a one way circlip instead of a round wire circlip, in this case you can carefully cut the sierra axle off as close to the cv as possible with a cut off wheell or an angle grinder with a very fine disc. You can then turn the cv inside out so to speak and pull out the remaining end of the axle.
Of course you could spend money and have 2 long sierra axles cut down and splined to suit the LJ centres, that way you could use 1300 axles with stronger cv's however it is not a cost effective method and the weak point becomes the spline you have just had cut because the the LJ axle spline is a smaller diameter to the 1300.
Highway-Star
Joined: Thu Apr 30, 2009 11:30 pm Posts: 4109 Location: Ipswich
 Posted: Sat Feb 13, 2010 1:16 pm |
what 2stroker said
Trent, I "think", to fit 1.3 CV's to a 1L housing you put the entire narrow track 1.3 CV's and axles into the 1L. I think its a straight swap
_________________ Clearance Hole Technology
