Joined: Sun Aug 23, 2009 11:30 pm Posts: 125 Location: central coast, NSW
Posted: Wed Feb 24, 2010 1:45 pm
nah not the clutch, the link between the gear stick and the gear box
the car is stuck in one gear and the gear stick flops around.
the clutch still works but i cant go anywhere because its stuck in 4th
so yea its some sort of link between the gear stick and the selector mechanism in the gearbox
Joined: Tue Jul 03, 2007 11:30 pm Posts: 1350 Location: stuck in a hole. not off road, just deception bay.
Posted: Wed Feb 24, 2010 2:34 pm
that will be the locating bolt for the gearstick. cheap and easy to replace. while your there you may aswell replace the shift bush too.
when your pulling the gearstick out you will see whats wrong. theres a slot in the loacting ball on the stick, in the housing there is a bolt which should have a turned down section which locates in this slot, but it won't be there.
Users browsing this forum: Google [Bot] and 298 guests
