It is currently Sat Oct 24, 2026 12:59 pm
Post Posted: Wed Mar 03, 2010 3:39 pm
hey all,
thanks to Ninjadaniel i got a replacement head light for my vitara, i got it yesterday and it looks to be in great condition::D
so my question for you vitara guru's is, do i have to remove the grill to fit the head light assembly?
i would rather not as if i take it out i doubt i would be able to get it back in, as its kind of bent ahah. ill put up some pictures when i can.
and if you have any general tips to make the install smoother, that would be much appreciated
thanks
Mitch
Vehicle: SJ50 hardtop!
Post Posted: Wed Mar 03, 2010 5:48 pm
I'll have to check mine after work, but I don't think you have to. I know my right hand headlight was a pain in the neck to get to, but with the right tools it's not too hard.
Be carefull with the grill if you do take it off. The plastic pins on the top of mine broke :(
NT SJ50
Post Posted: Thu Mar 04, 2010 12:37 am
thanks Bucket for that,
yeah the one that im replacing is the drivers side so hopefully it wont be to much trouble.
if anybody know more info please say.
thanks
Mitch
Post Posted: Thu Mar 04, 2010 3:03 am
I was just having a chat with dad, and from memory you do have to remove the front grill. It's pretty easy to remove, but yeah, take care with the plastic clips on the top of the grill when you remove it.
The bolts on the right hand side are a little harder to get to because you have the windscreen refill bottle in the way (at least on mine it was).
NT SJ50
Post Posted: Fri Mar 05, 2010 11:31 pm
anybody have any more info on this???
can they list the steps and how long it should take to remove and fit?
i wanna try and get this done for the meet on sunday, and i might be working tomorrow so time is limited.
thanks
Mitch
Post Posted: Sat Mar 06, 2010 12:29 am
Gday Mitch i just had a look at mine and yes you do have to take the grill off.
Then it looks like it would be ezyer if you took out the washer bottle then its just four 10mm bolts and the wiring and then ya done :P :wink:
Post Posted: Sat Mar 06, 2010 1:25 am
The grill has a few screws in the center near the sign and then clips along the top if I remember rightly.
NT SJ50
Users browsing this forum: Google [Bot] and 141 guests
