It is currently Tue Jul 28, 2026 6:13 am
Post Posted: Thu Mar 11, 2010 9:08 pm
Just a couple of quick questions.
Is the wheel arch the same on both NT and WT? As in same radius/shape...
Are the WT flare mounts spot welded on? And if so approximate number of welds?
Thanks
Post Posted: Thu Mar 11, 2010 9:11 pm
think they are the same radius, the WT flares sit higher up the guard. they are spotwelded on. i think there is a spot weld on average about every 100mm
Post Posted: Thu Mar 11, 2010 9:13 pm
Thanks
Yes
Yes
I think 8 weld's, go & get a spot weld drill bit, friggen awesome!!!!
Cost around $20 from a paint repair supplier & save yo stupid amount's of time & screaming. :P :wink:
Post Posted: Thu Mar 11, 2010 9:15 pm
ok thanks. that means i will be able to do a mock up on a bad body so if i make a mistake it doesnt matter :D
Post Posted: Thu Mar 11, 2010 9:16 pm
Yep. :P
Post Posted: Thu Mar 11, 2010 10:14 pm
hay ZF if you are slapping flares onto a NT sierra can you do a bit of a tech thread for us. i am about to do the same and i would rather someone else makes the mistakes. :lol:
Post Posted: Thu Mar 11, 2010 10:22 pm
I will do a thread on the removal of WT flares but thats not the plan sorry shep. I am going to make up some flares out of 32nb tube and was hoping not to make mistakes on my WT panels. They are going to be slightly wider than the WT flares and a hell of a lot stronger, just trying to decide at the moment whether I should join them into sliders and connect them to the front and rear bars to give stronger mounting points. So I am going to make one, attach it to the LWB, test to see if its strong enough (read jump on it) then if it passes it will go on the SWB if not a bit more designing to tie it all together...
Post Posted: Fri Mar 12, 2010 12:37 am
mmm check my build thread, already got pics on how to do it.
Vehicle: suzuki sierra coily
Post Posted: Fri Mar 12, 2010 6:40 pm
what ya doing with ya wide track flares once ya remove them??? mAre they going back on??? or they up for sale?
Post Posted: Fri Mar 12, 2010 9:25 pm
I'll be holding on to them for a while until the tube ones have proved themselves. Possibly selling them after that but don't hold your breath
Post Posted: Mon Mar 15, 2010 3:14 pm
i found these on the net.. they sell them for jeeps. they also do new jeep flares for 550.. is this wat you are making???? can you post a step by step make of ya flares
Users browsing this forum: Google [Bot], kamnandi and 528 guests
