It is currently Tue Jul 28, 2026 3:11 am
Post Posted: Sun Mar 14, 2010 2:33 am
i have bought a vitara and just wondering if anyone can help with with what parts of the wiring i need to take out with the motor to do a swap into a sierra ??
cheers brodie
100 series cruiser 4 inch lift and 35s
1990 sierr
Post Posted: Sun Mar 14, 2010 3:59 am
-take the entire wiring loom out, everything from behind the dash.
-you will also need the speedo cluster, more specifically the circuitboard that is inside/underneith the speedometer, this has to be transplanted into the sierra cluster carefully.
Personally i found it good to use the vitara wires and engine bay fuse box. This allows for better power through the car and thicker wires to the starter and alternator. If you use the fuse box you can use one of the fuses to run a wire to an amp if you have one.
It is an easy conversion to do, i did mine in 1 week without a wiring diagram.
Post Posted: Sun Mar 14, 2010 4:03 am
ohk then well i found by the looks off it the ecu for the motor on the drivers side behind the dash is that right ?? and as for the instrument cluster there isnt one in the car :S ??
cheers brodie
1990 sierr
Post Posted: Sun Mar 14, 2010 4:16 am
cheers brodie
Um nah want33s got that :oops:
You can make a VSS thingo so ya wont need the instrument cluster.Some fellas on here were making some the other day ill find the link for ya :wink:
Post Posted: Sun Mar 14, 2010 4:18 am
Found it :P
http://www.auszookers.com/index.php?nam ... pic&t=9978
There is two of em :P
http://www.auszookers.com/index.php?nam ... ic&t=10121
Post Posted: Sun Mar 14, 2010 4:24 am
i was speaking to mr rocky (mike) on here just then and he said i dont need the VSS all it does will minimise excess fuel usage i think he said with out it it would use 10ltrs to 100k's and with the vss in it would use about 8ltrs to 100k's
so not a big differecne it hink it will be alright for now ..
just need a hand with the wiring i dont no wat to take out lol
brodie
1990 sierr
Post Posted: Sun Mar 14, 2010 4:37 am
brodie
Well there ya go ive never heard of that one before....ya learn something new every day on here aye :P
As for what stuff to take out i wouldnt have a clue :?
Post Posted: Sun Mar 14, 2010 4:44 am
yeh im just gonna go off what mr rocky said follow what comes offf the motor and see where it goes to, take that and a lil bit more wiring lol and get all the earths and what ever else is on the firewall in the engine bay :P
and i should be alright :)
1990 sierr
Post Posted: Sun Mar 14, 2010 8:49 am
is it going in the black or white one?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Sun Mar 14, 2010 1:34 pm
If you dont get the VSS the check engine light will be on all the time.
Post Posted: Sun Mar 14, 2010 3:45 pm
not sure just yet what would you recommend putting it in to ??
cheers brodie
1990 sierr
Post Posted: Sun Mar 14, 2010 3:46 pm
oh ok well the VSS has been taken out of the vit already..
1990 sierr
Post Posted: Sun Mar 14, 2010 4:01 pm
You WILL need the vss, before i installed it with my conversion the engine would cruise fine but when you put your foot down to accelerate it would splutter before accelerating
Post Posted: Sun Mar 14, 2010 4:10 pm
so i need to fínd a VSS then ??
1990 sierr
Post Posted: Sun Mar 14, 2010 4:50 pm
Or make one...
I want my old sig back :(
Post Posted: Sun Mar 14, 2010 5:46 pm
my car runs fine with no vss as does my mates with the same motor.
maybe yours had an underlying issue, but the vss is not needed for the car to run fine, just a little richer.
Users browsing this forum: Google [Bot] and 536 guests
