It is currently Tue Jul 28, 2026 7:47 pm
Post Posted: Mon Mar 15, 2010 4:57 am
im after some advice when im in 4wd there is a nosie (knocking) which sounds like it is coming from the LHF of the car when im accelerating there is no nosie but if im slowing down or rolling thats when it starts it will even cause the tc to shake. what do ya 's think
Post Posted: Mon Mar 15, 2010 12:53 pm
Check the uni joints in the front shaft.
Post Posted: Tue Mar 16, 2010 2:08 am
yea there all ok
Post Posted: Tue Mar 16, 2010 2:13 am
have a mate shake it & check over the front end looking for the noise, it could be loose shackles, rooted shackle bushes, loose u-bolts...
or
someone suck in your engine bay & they're trying to get out?
Post Posted: Tue Mar 16, 2010 2:35 am
i dont think it is the shackles cos the tc starts to shake too im thinking could it be the diff or the axles, would they make a knocking nosie ?
Post Posted: Tue Mar 16, 2010 2:45 am
TC bushes or arms bent or busted resulting in the stick hitting on the body ?
Post Posted: Tue Mar 16, 2010 2:50 am
i forgot to mention that i have changed the tc and it still happend
Post Posted: Tue Mar 16, 2010 4:30 am
i had that and it was the leaver hiting the body...
could be nearly anything though
broken gearbox mount and box hitting firewall?
Post Posted: Tue Mar 16, 2010 4:48 am
If it was a gearbox mount you'd expect it in 2WD as well... It's gotta be somewhere in the front drivetrain.
I want my old sig back :(
Post Posted: Tue Mar 16, 2010 12:14 pm
no, there is much more load on the drivetrain in 4wd.
Post Posted: Tue Mar 16, 2010 12:18 pm
bet ya it is a fucked slip joint in the front tailshaft. :wink:
Post Posted: Tue Mar 16, 2010 1:49 pm
Was thinking that, or the front diff's about to go BUNG!!!! :P :P
Post Posted: Tue Apr 06, 2010 6:14 pm
whats the slip joint ? is that where the front shaft slides together? could it be the cv
Post Posted: Thu Apr 08, 2010 12:22 am
Vehicle: Nissan
Post Posted: Thu Apr 08, 2010 12:26 am
yes
Pearce-toff Racing
Vehicle: jimny
Post Posted: Thu Apr 08, 2010 2:13 am
wtf is a nosie?
Post Posted: Thu Apr 08, 2010 3:04 am
Noise
Post Posted: Fri May 14, 2010 3:17 pm
how can you tell when the slip joint is gone?
Post Posted: Fri May 14, 2010 9:28 pm
Same as a uni, grab it & give it a good shake, twist & pivot..
if it has noise or play while doing above said, it's probably buggered,
Try greasing it, if the noise/vibration goes away your in the right spot.
Should be greased on a monthly bases anyway, more if you only play in mud & water..
Users browsing this forum: No registered users and 744 guests
