It is currently Mon Oct 26, 2026 6:40 am
Post Posted: Wed Mar 17, 2010 1:51 am
ok first noticed this when i had the 31s on the rear that the diff sits 2 the left about an inch not really sure wat i could be
im thinking maby a bent hanger but it seems to handle fine
plz help
-indebt 4x4 club-
nav 32s n winch cust rear
Vehicle: suzuki sierra coily
Post Posted: Wed Mar 17, 2010 1:58 am
mine dose it to. but i think mine is due to 2 inch shackel lift
Post Posted: Wed Mar 17, 2010 2:01 am
yer mines alll standard so that aint it butm could still eb hanger/shackel
-indebt 4x4 club-
Vehicle: 2001 M18a Jimny
Post Posted: Wed Mar 17, 2010 2:03 am
Mine does it too, both on the front and rear. But i have a dodgy shackle on the front.
http://www.facebook.com/omalleyimagesonline
Post Posted: Wed Mar 17, 2010 2:05 am
Poor rear axle manufacturing tolerances?
My widetrack has a rear axle that measures somewhere between narrow track and widetrack. Can visually see that the rear is narrower than the front just quickly looking at my car, as its a good 20 or 30mm under length. Its also slightly offset to one side (can't remember which now, but its only about 5mm). Not as bad as Hiluxes which seem to notoriously have different wheelbases on each side of the vehicle :lol:
If it bugs you too bad, find another axle, and measure it up before you buy it, then swap it in. I've personally been driving my car for over 5 years now, and it has not bothered me at all :D
Clearance Hole Technology :P
Post Posted: Wed Mar 17, 2010 2:08 am
o ok well if its just a common fualt then it doesnt worrie me so much i just thought it was something twisted or stuffed that's all
cheers highway star
P.s if any one else could come forward and give me a confirmation or a different diagnosis im more then happy to listen
cheers luke
-indebt 4x4 club-
Post Posted: Wed Mar 17, 2010 2:15 am
cheers highway star
cheers luke
Suzuki's don't have fault's, thay have blemishes.
Post Posted: Wed Mar 17, 2010 2:31 am
Character, the word is character
Post Posted: Wed Mar 17, 2010 2:36 am
Yes boss!!! :roll: :P :P
Post Posted: Wed Mar 17, 2010 2:40 am
Makes them all individuals :P :roll: :oops: :lol:
Post Posted: Wed Mar 17, 2010 2:45 am
Just like me, me ,me ,me, me, me & me!! :P :? 8O :roll:
Post Posted: Wed Mar 17, 2010 2:47 am
i no this is probably different, but i have this on the rear of my vitara. one side sticks out by about 15-20mm and the other side is in by 15-20mm. just stock vitara but with 235/75/15 on sunnies. it was the same on my last vitara with same setup.
u cant really notice it tho as i have flares
Mitch
Post Posted: Wed Mar 17, 2010 8:16 am
On a vit I would be looking for worn bush's or movement in the center hemi joint, 10-15mm is not a lot tho.
Vehicle: SJ80
Post Posted: Wed Mar 17, 2010 11:36 am
Yep, noticed my wheels stuck out a bit when I first did my lift and tyres. Even more so when I added shackles to the equation. Worried me at first but seems to be a common thing.
Post Posted: Wed Mar 17, 2010 2:43 pm
plz help
Where are you referencing it from? The body? Is it straight? Im assuming that all your rims are the same as well ie offset.
Dan
Post Posted: Wed Mar 17, 2010 10:27 pm
my sierra also sticks out.. but i am sitting on sagged rims on the drivers side..
if you jack the chassis up till it sits all nice and even then the wheels sit equally out of the guards
its all a visual thing.
Users browsing this forum: Google [Bot] and 268 guests
