[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
plopp
Joined: Fri Dec 18, 2009 10:30 pm Posts: 75 Location: brisbane
 Posted: Thu Mar 18, 2010 6:20 pm |
hey guys
I have just completed a 50mm body lift in my coily and just took it out for a spin. A problem though I was looking to see if anyone else had encountered. The gearbox it appears will not stay in gears 2, 4 and Reverse ( the downwards shift) and has no problem staying in 1, 3 and 5th. It just pops out of gear. I am thinking it may be because the gator (I believe its called, the rubber thing over the gearstick connecting to the body) might be restricting movement. I also have a plastic vinylish flooring installed, which may also be hindering the movement.
Anyways, just looking to see if anyone else had encountered the problem before i try mucking around with things.
Cheers.
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Thu Mar 18, 2010 6:28 pm |
cut and shut your gearstick to be further foward, or raise your gearbox.
_________________ builder of custom road legal zooks......and stuff.
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Thu Mar 18, 2010 6:48 pm |
Trim out the steel ring that retains the rubber boot. If you take 5 - 10mm out of the bottom of the hole in the ring it will allow the boot to flex enough not to push the lever out of gear.
Heaps easier then modding the gear stick.
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
plopp
 Posted: Thu Mar 18, 2010 7:08 pm |
cheers just cruzin
I have an old fabric boot from my old car lying around somewhere at home, would this work instead of cutting into the bottom of that ring?
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Thu Mar 18, 2010 7:35 pm |
I took my inner boot completely out. Fixed the problem for me
_________________ Shep is a closet jimny lover!!!!
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Thu Mar 18, 2010 8:41 pm |
Which ever boot you use you still need to trim the ring
plopp
 Posted: Thu Mar 18, 2010 10:16 pm |
yeah all good, i cut back the ring with a hacksaw and filed it neatly and removed the inner boot and was good to go, thanks guys.
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 72 guests
