It is currently Sat Oct 24, 2026 2:46 pm
Post Posted: Wed Mar 24, 2010 4:44 am
My choke seems to come on after the engines warm. Ive spayed the linkages a few times, it goes away then returns after the next drive. Any ideas? I did get some water splash into the cover. Maybe causing it to stick? Can I remove the auto choke? Any help to solve this will be great.
Post Posted: Wed Mar 24, 2010 11:33 am
check your coolant isnt low and the hoses arent blocked
Post Posted: Wed Mar 24, 2010 1:24 pm
ok, when i got it the raidator was making gurgling noises, not overheating on the gauge though. I then replaced the thermostat and that fixed that. Ive drained the coolant into a bucket. top up with water drove down to the school and back(engine still reeving hard) come back and drained it. ill wait till shes cool before i top up. Hmmmm :cry:
Post Posted: Wed Mar 24, 2010 2:07 pm
you know when you drain the coolant you need to top up preferabley with the engine running once the thermostat opens?
Post Posted: Wed Mar 24, 2010 3:13 pm
Hey thanks. Yeah turned in over as i was topping back up with coolant. Problem solved. Car running alot better now too. Maybe i should turn heater on and give it a blast of water in there. Havent turned the heater on yet. Should you turn heater on before flushing motor? Thanks again for your help. Dave :D
Users browsing this forum: No registered users and 102 guests
