It is currently Sat Oct 24, 2026 9:25 pm
Post Posted: Fri Mar 26, 2010 10:00 pm
hi all,
i am looking to buy a particular zook but i am a bit iffy about this one. and never owned a zook. some advice/opinions would be greatly appreciated
its a '94 SWB thats done 290,000
recently replaced engine with reco engine ~5K ago
the clutch was also done but i suspect wrongly. drove it today, and it really suddenly grabs at a point quite far out. horrible! i wouldnt know whats wrong. easy/cheap fix?
the car is very rough but $1500 which is pretty cheap i understand for these goers. dunno if i would be getting something thats too much to get on the road, as he wants to sell unreg
i would like a zook but dunno if this is worth the effort to get a road worthy.
thanks again, and could be seeing all you brissy/goldy zookers out there soonish... pending.
Post Posted: Fri Mar 26, 2010 10:03 pm
Spend the extra, buy a good one. It'll cost you less in the long run...
I want my old sig back :(
Post Posted: Fri Mar 26, 2010 10:06 pm
Where is the car at mate??
Might be able to look at it if it is local to me
Post Posted: Fri Mar 26, 2010 10:13 pm
ask the guys on here someone close will be able to check it out for you my clutch is the same and only just been changed so the previous owner said but my clutch cable is so stuffed and needs to be replaced so once i change it im hoping it should be fine :D
Vehicle: jimny
Post Posted: Fri Mar 26, 2010 10:43 pm
My clutch is right at the bottom, only cause it's old and my cable is twenty years old. New clutch should pu the pedal right at the top I reckon As would a new un stretched cable. It is pretty cheap at that price anyway
Post Posted: Fri Mar 26, 2010 10:49 pm
you can adjust the cable so it takes up anywhere you want!!!!
if its a new HD and you arent used to it they will seem pretty aggressive, youll appreciate it when you are leaning on it on a big hill
Users browsing this forum: No registered users and 183 guests
