It is currently Sat Oct 24, 2026 2:03 pm
Post Posted: Mon Mar 29, 2010 12:23 am
hey guys
I've got a 1.3 in my Sierra I've had this fuel consumption problem since I got the car. I had one weber on it,then I got rid of it and put a standard carby back on it. It was still shit like 160kms to a tank, then i changed to another weber. The previous owner said he got 300 to 350 to a tank and i still got 160kms to a tank. I had a electric fuel pump on it so I took that off and put a new mechanical fuel pump on it. I blew out the feed & return line because i thought the return line might be blocked and forcing fuel into it.l I've changed everything except for the tank and cap. oh and i adjusted the throttle so it only opens the primary throat so the secondary throat wont open. I have even tried driving like a grandma as well, what else can i do?
Post Posted: Mon Mar 29, 2010 12:25 am
specs on vehicle?....tyre size etc?
Post Posted: Mon Mar 29, 2010 12:26 am
How good are tha carbies?Service and tune up? 160km's sounds pretty shity. Mine gets around 330ish
Post Posted: Mon Mar 29, 2010 12:33 am
its the 1.3 with a 1ltr transfer not sure on diff ratios they are 89wt diffs and 32's on it. ive rebuilt the engine and its just about ready to get its first service. but since the carby was gettin good fuel consumption before i dont think that its the carb and 3 carbys did the same thing.
Post Posted: Mon Mar 29, 2010 12:36 am
skitzlux wrote:
32's on it.
Post Posted: Mon Mar 29, 2010 12:40 am
i used to have 32's and 1.0 trans box and i was lucky to get 100ks out off the tank.
Post Posted: Mon Mar 29, 2010 12:45 am
8O mine had 33s and i was still getting at least 260 kays to a tank
Post Posted: Mon Mar 29, 2010 1:01 am
mine where shaped like this.
Post Posted: Mon Mar 29, 2010 1:03 am
Its the t'fer case...take it out and sell it to me :comeon: :please:
Post Posted: Mon Mar 29, 2010 1:04 am
:lol: ive seen em do that around the whole tyre :P
How long were ya running them for before they done that?????
Post Posted: Mon Mar 29, 2010 1:27 am
what did you guys do to fix it or am i always gunna chew fuel will 6.5s help or be worse?
Post Posted: Mon Mar 29, 2010 1:33 am
you need to work out the actual distance traveled, due to the transfer case & bigger tyres your speedo will be out massively.
Vehicle: Suzuki
Post Posted: Mon Mar 29, 2010 1:35 am
atleast they are round shep!
Post Posted: Mon Mar 29, 2010 1:36 am
x2 My odometer says 280 to empty but works out to approx 330
Post Posted: Mon Mar 29, 2010 1:59 am
my fuel gauge dont work but i try and fill it up every 250km's and thats some time alnmost a full tank gone or atleast 30ltrs gone and im running 3.7's in the diffs 6.5's in the case and 31's
brodie
100 series cruiser 4 inch lift and 35s
1990 sierr
ive got a 1lt case here if you want it it doesnt have a 4wd switch tho, and does anyone have the formula to work that out
Post Posted: Mon Mar 29, 2010 2:00 am
Trans or diff gears will sort out your fuel useage problems. I get 200ks out
Of a tank now. On the road I can go from darwin to katherine on a tank, I think that is
350ks. I should proberly state that I only have 2 gauges that work, temp and fuel.haha
ha
Post Posted: Mon Mar 29, 2010 2:13 am
haha yeh i think thats how zooks come factory with only a couple of working guages lol
i got and aftermarket temp guage thats works but the others dont like fuel and the other temp in the cluster my speedo and revs works thats about it :P
1990 sierr
Post Posted: Mon Mar 29, 2010 4:15 am
hey guys if you need them i have 3 dash inserts here that all the guages work on.
Vehicle: SJ80
Post Posted: Mon Mar 29, 2010 4:31 pm
The previous owner was full of shit maybe? 350km on that setup is pretty ambitious.
Post Posted: Mon Mar 29, 2010 6:09 pm
i have no dash lights or speedo or tacho, just fuel and temp and i reckon they are getting a bit suss. :wink:
Post Posted: Tue Mar 30, 2010 2:56 am
ewww very nice shep :) now i got no indicators thats work or come up on the cluster is that good enough for ya shep lol
1990 sierr
Post Posted: Tue Mar 30, 2010 12:57 pm
What do all your plugs look like?
How is your timing?
How dented is your fuel tank?
I started getting annoyed at having a 160km range, mainly because my stock fuel tank would only hold about 20L.
Post Posted: Tue Mar 30, 2010 9:47 pm
timing spot on and it has a dint but it holds 35L so does anyone know the formula to work it out
Post Posted: Tue Mar 30, 2010 10:27 pm
I would inspect your plugs, and see what they look like. How is your airfilter? and what sort of driving do you do? Long slow cruises, or lots of short city trips where you flog the ass out of it? Or long cruises at wide open throttle (WOT)? etc.
If its too hard, just fit a much larger fuel tank.
I put a vitara fuel tank in mine.
As a DD i use stock wheels and have 6.5 transfer gearing installed.
100km/h is like 4400 rpm.
With my 32x9.5 pedes on (33.4 OD) i get decent fuel consumption. But obviously not enough to warrant the annoying noise and extra cost of tearing up my pedes.
With stock tyres I have recently been getting:
at 80km/hr on the highway i get 8l/100km.
At WOT on the highway i've been getting about 14L/100.
Doing city driving im getting 14/L/100km currently too.
I have also been having issues with 1 cyclinder running rich at WOT. Which is why i was so down on power and using a lot extra fuel on the highway. Only discovered the issue, when I inspected the plugs.
Hopefully it is sorted now.
Post Posted: Wed Mar 31, 2010 5:00 am
32's are 23% larger than factory... so whatever your odometer says, add 23%... ie: 160km = 196.8 - which is still crap.
I get about 260-280km from a tank (30L) with 5.14 tcase gears and 31s (simex ETs) (92 WT sierra). Pretty happy with that - of course i'd like more, but with that tyre choice i cant expect better.
Oh - and mines 1.6 EFI too - that accounts for a little more fuel usage.
Post Posted: Wed Mar 31, 2010 5:26 am
So you have smaller tires, and lower T-case gearing, its not surprising you get better economy then...
If you wanna run 32s and get reasonable road performance from them, you need to get the right gears... 6.5s would be the go...
I want my old sig back :(
Users browsing this forum: No registered users and 236 guests
