It is currently Sun Oct 25, 2026 6:54 pm
Post Posted: Mon Apr 05, 2010 12:31 am
HELP!
my 87 zook alternator is on the way out. it wont idel and wen it does its as rough as heshin undies, next my brother tried to jump start his HQ ute off it and now it wont start!!!! :cry: if u turn the key on to run u get oil and battery lights and wen u turn the key to start the lights go out... and nothing no clicks nothing 8O i'm lost. any help would b awsome thanks heaps people
Vehicle: 4wd
Post Posted: Mon Apr 05, 2010 12:33 am
flat battery?
Watch out or you'll get sued.
Post Posted: Mon Apr 05, 2010 12:39 am
yeah tried that sorry forgot to mention it
87' sierra with 31's
Post Posted: Mon Apr 05, 2010 1:14 am
OK people just for the laymen out tere the alternator has nothing to do with starting your car. The alternator simply recharges your battery and runs the electronics while the engine is running.
Just because your battery shows 12v when you check it with a multimeter does not mean its good.
If you know its a electric problem start with checking all your grounds and connections. Check the water leavels, get it load tested. Check the complete output of the alternator. Check it with loads on/off, at high revs low revs.
Then you need to check the starter/solenoid. Then if all that is good you need to move on to the ignition switch. Simply put there is more to checking a starting /charging system then checking battery voltage.
Post Posted: Mon Apr 05, 2010 1:27 am
But from reading your problem you need to check the signal wire at the starter (the small wire) its probably unplugged or bad connection
Post Posted: Mon Apr 05, 2010 1:34 am
check fuses
and starter wires
Vehicle: 92 Suzuki Sierra
Post Posted: Mon Apr 05, 2010 7:19 am
x2
makes an excellent immobiliser 8)
-Santos
Post Posted: Mon Apr 05, 2010 12:26 pm
Sounds to me like the battery has dropped a cell. Do all the other checks as Dave suggested and take the battery somewhere to be checked properly
Vehicle: LJ20 LJ50
Post Posted: Mon Apr 05, 2010 12:48 pm
Your brother probably stole your battery and put his dead one in his car....
Camels have nice toes
Post Posted: Mon Apr 05, 2010 1:57 pm
ok checked fuses they're all good. swapped battery with a new one still nothing
the starter motor still works if u use a screw driver???
Post Posted: Mon Apr 05, 2010 2:30 pm
Do you mean it works if you short out the contacts? Then you have a dead solenoid on the starter.
Post Posted: Mon Apr 05, 2010 3:30 pm
Suzis run a 2 pole starter, and go well, then stop dead.
Post Posted: Tue Apr 06, 2010 11:04 pm
i think your rite about the starter motor. is there anyway to tell if the ignition has shit itself???
Post Posted: Tue Apr 06, 2010 11:23 pm
Can you use a multimeter, or get someone who can.
Test the power at the battery, the at the starter motor poles, if its there, and there is nothing, its cactus.
That would be my first port of call, then after do the ignition bit.
Post Posted: Fri Apr 09, 2010 12:31 am
all good guys it was the in-line fuse or what should have been it (speaker wire) was fried so just fixed it up and its all good as gold thanks everyone for the advice
cheers marc
Users browsing this forum: No registered users and 168 guests
