It is currently Sat Oct 24, 2026 8:51 pm
Post Posted: Thu Apr 08, 2010 1:09 am
how do people but checker plate on there sills?
Post Posted: Thu Apr 08, 2010 1:12 am
sikaflex and rivets
Post Posted: Thu Apr 08, 2010 1:13 am
yea but there is that bent up steel where the plastic mounts too do you take that off or not?
Post Posted: Thu Apr 08, 2010 1:16 am
grind that off mate.. and paint it
then sikaflex the checker plate on
Off....grinder, sikaflex then rivets :wink:
Post Posted: Thu Apr 08, 2010 1:19 am
sorry. yes you need a bare sill before you put the chequer down. rip the plastic off then for the metal holders you can either go real slow with a griding disc on a grinder or do it properly and get a spot weld drill bit. then give it a lick of paint, sikaflex it in place and rivets as well.
my advice is don't do it. i did it to mine and i wish i hadn't...
Post Posted: Thu Apr 08, 2010 1:20 am
ok thanks guys. can you buy black checker plate or do you have too paint it
Post Posted: Thu Apr 08, 2010 1:21 am
etch primer first then paint.
Post Posted: Thu Apr 08, 2010 1:23 am
ok thanks for you help
Post Posted: Thu Apr 08, 2010 1:33 am
how do yous go about sand getting behind the checker plate or water leaking into car where you drill holes for pop riviots
Post Posted: Thu Apr 08, 2010 10:15 am
Water won't leak in, it's just the outside skin your drilling into. If you seal
it properly sand and the like shouldn't get in, you will just have to be a bit more cautious when cleaning and pay a bit more attention in that area
Post Posted: Thu Apr 08, 2010 11:14 pm
Why checkerplate? It doesn't slide on anything - it's designed to provide grip for your feet, not slide like you want your car to do on a rock.
In fact, you don't want alloy at all - it galls and grabs on rock in common grades.
go with smooth material, probably 1.6mm of steel IMHO.
It can still be attached as per the other posts.
Post Posted: Thu Apr 08, 2010 11:27 pm
What about carbon fibre? :roll:
Post Posted: Thu Apr 08, 2010 11:33 pm
I had to laugh at this :lol: :lol: :lol: :lol: :lol:
I prefer the idea of just grinding the top layer (folded sheet steel) away rather than drilling holes right through but each to their own :P
Post Posted: Fri Apr 09, 2010 12:05 am
thats how i did it as well but i also made a few mistakes. i would have prefered a few small holes then some of the cuts i made..
Post Posted: Fri Apr 09, 2010 11:26 pm
i just wanted it for look's because the plastic looks like shit
Post Posted: Fri Apr 09, 2010 11:42 pm
my spot weld drill is like a little hole saw with a spring loaded center pin and it
just cuts the first layer. only rough people go all the way through. :wink:
Post Posted: Fri Apr 09, 2010 11:59 pm
personally i think the plastic is great visually (style wise) but not aesthetically - when mine get too rusty ill be getting 1.5mm steel folded to the correct shape, painted and bolted on - it might not be super strong but will look factory still, and be stronger than the plastic.
Post Posted: Sat Apr 10, 2010 3:33 am
I used grinder to remove the metal bits, but not grinding disc but medium or fine flapp disc (can't remembre now which one was it ) it it was fine, I had a lot of rust, and cleaned it with flapp disc, takes longer. than I fabricated side steps and rock sliders like those ones http://www.lowrangeoffroad.com/index.ph ... iders.html
However I didnt mount them to the chasis and body, but only to the body. I didn't like the idea of having body and chasis being bolt solid together with without bush.
Users browsing this forum: Google [Bot] and 137 guests
