It is currently Sun Oct 25, 2026 1:52 pm
Post Posted: Thu Apr 08, 2010 11:51 pm
ok, me and my house mate pulled my G16A vitara apart, i had a cracked head.
sent it away, welded, straitened, machined..
we've put it back together and it wont bloody start.
new leads, plugs, cap, rotor. VRS kit,
everything seems lined up, timing seems ok. makes no shitty noises when it turns over, sparks @ the plug and has compression..
what more can we check for??
any ideas welcome..
Post Posted: Thu Apr 08, 2010 11:56 pm
Is the G16A injected? I cant remember, if so maybe a sensor is disconnected, not getting power to fuel pump, etc... it could be a million things. About timing too, did you set the timing up 180deg out, it does matter.
Vehicle: 105 landcruiser
Post Posted: Fri Apr 09, 2010 12:00 am
might be out of time.. you might be on the wrong revolution.. 180 degrees out.?
Vehicle: Nissan
your compression may be on cylinder 4 and not cylinder 1?
Pearce-toff Racing
Post Posted: Fri Apr 09, 2010 12:01 am
G16A is carby...
Sounds like you have one of two things wrong..
1, Cam - crank timing is incorrect.
2, Distributor timing is incorrect.
Vehicle: 4wd
Post Posted: Fri Apr 09, 2010 12:09 am
try connecting the battery
Watch out or you'll get sued.
Vehicle: Nissan
Post Posted: Fri Apr 09, 2010 12:11 am
well it turns over so it wont be that :wink: :P
Pearce-toff Racing
Vehicle: 4wd
Post Posted: Fri Apr 09, 2010 12:13 am
:lol: :lol: :lol: :lol:
Post Posted: Fri Apr 09, 2010 12:21 am
timing not 180 out,
made sure the belt hasn't jumped a tooth, i think after tea were gonna do a full compression test and maybe take the top cover off and have a look inside..
tis annoying, i just wanna drive the bloody thing.
Post Posted: Fri Apr 09, 2010 12:25 am
morpheus wrote:
timing not 180 out
Try it for shits and giggles, can't hurt :wink:
Vehicle: 4wd
have you checked your getting fuel?
Post Posted: Fri Apr 09, 2010 12:34 am
yeah gettin fuel,
how much compression should it have each cylinder??
Post Posted: Fri Apr 09, 2010 12:43 am
I THINK its around 120-140psi??? Don't hold me to it, i'm probably wrong. As long as there isn't a great deal of difference betweeen the 4 it should be ok
Post Posted: Fri Apr 09, 2010 12:44 am
ok how do you know the timing is correct?
how do you know there is fuel in the carb?
how did you time the cam, both keyways up like every other engine or the cam keyway down like a G16 should be :wink:
Yep, that'll do
Post Posted: Fri Apr 09, 2010 12:45 am
So while cranking the motor and rotating the dizy 360 degrees , bolt removed and holding down , you get no firing at all , that would mean the timing is out or it is flooded when in the right position and not able to fire , Cheers Paul.
Post Posted: Fri Apr 09, 2010 1:25 am
out of curiosity, the rear cam seal, does it look like the front cam seal or is it an o-ring??
Vehicle: 4wd
Post Posted: Fri Apr 09, 2010 6:35 pm
Did you work out what it was yet?
Post Posted: Sat Apr 10, 2010 7:48 pm
yeah i got the thing running... finally.... although a lot of oil is coming out the back of the top of the motor somewhere.
i fear maybe the rear cam seal has not gone is?? problem is, we didn't pull them out, the boys @ the head repair place did, so we dont know what were looking for...... and in the VRS kit i have a rubber ring, perhaps 4-5cm round with a wall thickness of maybe 3mm... and its orange..
should that be on the back of the cam??
everything in the VRS kit has been used, apart from this bloody orange ring..
Post Posted: Sat Apr 10, 2010 8:43 pm
What was wrong with it??
Post Posted: Sat Apr 10, 2010 10:37 pm
i dont know, i got home and looked @ it myself (my mechanic friend was doin all the work)
took my time, called someone i know is VERY good with cars, followed his instructions EG, take rocker cover off, make sure the valves lift @ the right time when piston 1 in TDC, make sure the dizzy is on the right cyliner. make sure the leads go to the right plug, i played with the distributor position a little, and it started..... needed a gut full of throttle though, but it started.... and i eventually got it to run without my foot on the pedal, then was able to set the timing........
so. my "mechanic" house mate couldn't get it started..
im a computer nerd.. hate gettin my hands dirty, and with some instructions.. i got it started...
in saying that, i would no way have been able to put all the bits back together like he did.. lol
Post Posted: Sun Apr 11, 2010 1:59 am
so no one can tell me what the rear cam seal looks like??
Post Posted: Sun Apr 11, 2010 3:37 am
Do you have a 90 degree dizzy drive , if so the cam seal should be a O ring , does it bolt on with 3 bolts , Cheers Paul.
Post Posted: Sun Apr 11, 2010 9:00 am
yeah bolts on with 3 bolts, and i remember putting a thin o-ring in a groove on that part.. but its still leaking oil REALLY bad from the back somewhere..
Post Posted: Sun Apr 11, 2010 11:32 am
Gasket around the housing of the dizzy drive, or rocker cover
Post Posted: Sun Apr 11, 2010 3:41 pm
both new, and seems to be more dizzy area, maybe the seal moved when we put it on the head. but its leaking heaps..
Users browsing this forum: Google [Bot] and 175 guests
