It is currently Sun Oct 25, 2026 4:09 am
Post Posted: Tue Apr 20, 2010 4:25 pm
Having difficulty finding where all the vacuum points should be conected on my carb and the pipe from the fuel pump cable tied up also the cable tie on the choke?? I believe?? Any help would be much appreciated :)
Vehicle: SJ80
Post Posted: Tue Apr 20, 2010 4:51 pm
Yes, looks like your auto choke has been cable tied for some reason.
Those carbs have a wax pelet that actuates the auto choke - and they don't last forever. Need to check that hot coolant is actually flowing through the small coolant pipes near the choke. Need to ensure the spring/wax pelet is actuating the choke as it should when cold, and coming all the way off when hot.
What problem are you actually tring to fix?
Post Posted: Tue Apr 20, 2010 6:00 pm
Car runs ok'ish just confused as to all the empty vacuum pipe connections and the fact that i have to keep the revs on till she warms up, obviuosly a choke problem will check out pelet etc thanks
Users browsing this forum: Google [Bot] and 133 guests
