It is currently Sun Oct 25, 2026 12:32 am
Post Posted: Fri Apr 09, 2010 5:38 pm
Noise from gearbox or something
only happens when at low revs in each
gear no idea what it is any ideas
Sounds like my car is gunna blow up
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Fri Apr 09, 2010 8:13 pm
try uni joint's that fixed mine and also change the gear box oil.
Post Posted: Tue Apr 20, 2010 1:33 pm
Uni joints fixed noise still there could this be
my transfer case?
Vehicle: SJ80
Post Posted: Tue Apr 20, 2010 6:17 pm
So the noise is there, no matter which gear you select? and in both 4x4 and 2x4 on the transfer?
Are you sure it is coming from the centre of the car? not a diff or wheel bearing?
No obvious looseness or leakage from any of the shaft uni's or in the diff pinions, etc?
Next step would be to get it up on a hoist, and have listen while underneath.
Post Posted: Tue Apr 20, 2010 9:03 pm
My moneys on the uni joints... It was exactly the same in my car recently, as soon as you started accelerating you could hear the sound of metal tapping on metal until you got up in revs, then it disappeared...
Put the car in gear, Get under the car and try rolling the drive shaft or tail shaft around - there should be no movement at all. If there is a fair bit of play, replace the uni joints - only costs around $50 for a set of two, and you can do it yourself on a saturday afternoon... (i did it last saturday arvo) (a uni joint press makes it a lot easier - if you don't have one, you'll want a socket set, a good hammer, and a can of WD40)
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Wed Apr 21, 2010 12:28 am
f;ange bolts? sound shagged,
i had a similar noise actually, only whne i accelerated in 3.4.5 i hurd a whining grinding noise, got to the point were ever gear was fuked, couldent talk on my phone, turned out to be a crushed bearing in my pinoin :(
Skuxx
Users browsing this forum: No registered users and 156 guests
