It is currently Sat Jul 11, 2026 5:16 am
Post Posted: Tue May 04, 2010 10:25 am
he guys im in need of a rear 3.9 diff ctr. My welded diff is about to explode and i need a new one here for when it happends.. perfer melb pick up. Pm me if ya can help.
Post Posted: Tue May 04, 2010 10:43 am
Can you get the side gears out of yours??
I have a few 3.9 fronts here if you can change the side gears.
Jas.
Post Posted: Tue May 04, 2010 12:09 pm
i have a rear centre 3.9 with a lockright in it.. im going to put a mini spool in .. but im in perth :S
Post Posted: Wed May 05, 2010 10:12 am
thats exactly what i'll be putting in this new rear diff. thus the reason i need a new ctr. everything has been welded together and the crown wheel has some wear marks on it from last time the welds exploded and busted the bolts holding the ctr together.
Post Posted: Wed May 05, 2010 10:38 am
You can fit a mini spool to a front diff to make it a rear...
PM me if you want a 3.9 with a spool already fitted or if you want a front centre to fit your spool to.
Post Posted: Wed May 05, 2010 11:19 am
already got 2 spare 3.9 front diffs. What im after is a rear so i can put my lockright in. i need a complete ctr with the crown wheel as mine has damage to the teeth.
Thanx for the other offers but.
Cheers B4T
