It is currently Wed Oct 28, 2026 2:17 am
Post Posted: Thu Apr 22, 2010 5:31 pm
hey guys sort of new o the siera game, just wondering if a g13ba will bolt straight in and if the manifolds off my g13a will fit straight on? if not will the manifold off the g13ba take the standard sierra carby?
all help would be greatly apprieciated
thanks dan
Post Posted: Thu Apr 22, 2010 5:37 pm
A standard sierra has a g13ba motor already.
Has yours been modified?
The g13a is out of a swift.
They are all very similar motors.
1298 or 1324cc
Your post was very hard to read. What type/year of sierra do you have?
If the g13a is in the car already, yes swap everything to the g13ba. (the 'ba' should be setup already anyway)
Post Posted: Thu Apr 22, 2010 5:41 pm
Nope, not all of them.
Depends on the year, the early 1.3s were a G13A...
I want my old sig back :(
Post Posted: Thu Apr 22, 2010 5:51 pm
Ah,k so they were:
Early G13a's are 1324cc's.
Later G13ba's are 1298cc
Swift G13a's are 1298cc?
Post Posted: Thu Apr 22, 2010 6:12 pm
Early Swift and Sierra 1.3s are both G13A, 1324cc
The G13BA (1298cc) found its way into the engine line up during 1989 IIRC...
Post Posted: Mon May 03, 2010 1:11 am
hey guys is a early 85 nt and yer its the 1324cc but really tiered and loves its oil lol was goin to put a 13ba in it cause a mate has one and it goes noticably different
Post Posted: Mon May 03, 2010 2:29 am
I have both and they both suck balls, and/or oil:D
G16b way betterererer :lol:
Post Posted: Thu May 06, 2010 2:31 am
how hard is a g16 swap? im a diesel fitter so keep in mind im mechanicly minded lol
Post Posted: Thu May 06, 2010 7:02 am
Piss easy.
Well way easier than a 4L v8 into a 40 series..
Post Posted: Thu May 06, 2010 8:05 am
Get an adaptor kit and it just about does everything for you.... ;)
Though obviously if you go G16B its EFI, and the electrical stuff will be the hard bit... ;)
Post Posted: Fri May 07, 2010 3:02 am
mmm electrics lol we dont get along very well haha
Post Posted: Fri May 07, 2010 10:51 am
not quite...
Sump and pickup is different in the vitara, you will need to run a modified sierra sump and pickup as the vitara sump will smack the diff housing.
standard sierra starter motor will also hit the block, upgrade it to a reduction drive or grind the side of the starter motor down until it clears the block.
also vitara conversions are very dirty as the throttle body points towards the passenger side, its a messy bit of pipe work to make your way back over to the drivers side. Use Jimny Injection gear and camshaft with coilpack setup and baleno 1.6 injectors. The throttle body points towards the front then and you can make up a pipe to go back down to your sierra air box.
Post Posted: Fri May 07, 2010 10:55 am
not quite...
not necessarily, i know of a few 1.6 with vit sump in sierra conversions that have had no clearance issues.
my spring under SWB is one of them. :wink:
Post Posted: Fri May 07, 2010 10:58 am
did you raise the height of the motor via the mounts?
Post Posted: Sun Jul 11, 2010 6:29 am
sorry to sorta hijack thread but has anyone put a 1.5l twin cam swift motor in a sierra? like 2007 sorta model? seem to have good power/torque and are a half decent price. how easy a fit is it? or not worth the hassle
Post Posted: Sun Jul 11, 2010 6:44 am
By no mean's an easy fit, you will need a jimny g/box ( you just made a weak point) & all the plumbing & manifold's of a jim to, if you plan on using the swift Ecu you may want to figure out a way to either bypass the immob or run the swift bcm ( body control module).
Once in tho, it would be very responsive & FAST! :twisted:
Users browsing this forum: No registered users and 310 guests
