It is currently Mon Jul 13, 2026 1:30 pm
Vehicle: Jimny, Lifted on 30's
Post Posted: Sun May 09, 2010 3:05 am
looking for a set of 60% or more tread mud terrain tyres and rims 215/75/r15 that will fit straight onto a stock jimny. I live on the Sunshine coast so willing to drive a hour either side to collect.
Post Posted: Sun May 09, 2010 5:30 am
hey mate, as far as i know there are only three types of MT's you can get in that size. BFG MT's, Hankook Dynapro MT's (what i have) and the other i cant remember.
just be aware that if you put them straight onto a Jimny with stock suspension you may get some bad scrubbing. and you may need a lift.
Post Posted: Sun May 09, 2010 9:28 pm
Thanks alot! Maybe i should try the 205 muddies if there is such a creation. Lift is in the books but not going to happen for a year or so unfortunately.
Jimny, 3" Lift, 30" Treps, Gears
Post Posted: Tue May 11, 2010 10:04 am
Go the 215s with a set of coil spacers. Cheaper than a spring lift and will give the bigger tyres some breathing space
Post Posted: Thu May 13, 2010 1:24 am
So canced the spring lift and get coil spacers? will they the 215's then fit on a stock jimny? or do you meen go 2 inch lift and coil spacers? can i still get insurance or road legaled with spacers?
Post Posted: Thu May 13, 2010 4:25 am
If you're worried about legality you'll need to check regarding spacers. SOme people say they're illegal and some don't. Was just thinking spacers until you get spring lift. I run springs and spacers and have not had any mechanical issues with them. Mine is a total of about 100mm above stock plus the extra height that comes from the 235/75R15s. Looks tough but doesn't look like a huge lift so won't draw attention.
Post Posted: Thu May 13, 2010 5:07 am
Great thanks for bringing spacers to my attention i had not previously thought of them as an option but they actually seem like they might save me alot of money in the meen time! And they would be cheap to get taken out if there were any legal issues anyway so thats good :)
Post Posted: Thu May 13, 2010 5:26 am
really easy to put them in. with your standard springs would be an hour tops.
Vehicle: Suzuki Grand Vitara XL7 2004
Post Posted: Thu May 13, 2010 7:16 am
yup, i put in my front spring spacers and it took around maybe half an hour... to do it all.
i'm seriously depending on putting the rear spacers in or not though....
:( but i paid $52 inc postage to my door step and this if for 30mm spacers... ;)
Post Posted: Thu May 13, 2010 4:19 pm
Thats great, well i dont know much except the basics about cars so has anybody got a step by step on installing the spacers? or picturesa link? Thanks Guys! :)
Post Posted: Thu May 13, 2010 9:41 pm
I've just made a thread in Tech showing the install. Lucky I took photos :D
Installing coil spacers on a Jimny
Post Posted: Fri May 14, 2010 1:35 am
LIFE SAVER! Thanks alot Mate makes life alot easier! thinking a 2inch spring lift and then 40 coil spacers! looks awesom! Nice truck by the way!
Post Posted: Fri May 14, 2010 1:49 am
If you're going to combine the two you'll need longer brake lines
Post Posted: Fri May 14, 2010 7:18 am
Okay cool thanks for your help the pics and explination make installing that so easy! Thanks alot
Post Posted: Fri May 14, 2010 11:24 am
Didn't want to dirty up your other thread which i read earlier today. Where did you get your spring spacer from and what material are they made from?
Seems like a quicker way to get that little extra travel without forking out for the new gear.
Mitch.
Mitch.
Post Posted: Sat May 15, 2010 1:02 am
Contact ODA1 for spring spacers. He has a range of sizes.
Post Posted: Wed Jan 12, 2011 10:28 pm
Will I need to replace the factory shocks with 40mm spring spacers?
Post Posted: Wed Jan 12, 2011 11:42 pm
If you'll only be using the 40mm spacer with stock springs the standard shocks will probably be OK.
Users browsing this forum: Google [Bot] and 36 guests
