It is currently Tue Jul 28, 2026 7:08 pm
Post Posted: Fri May 14, 2010 9:41 am
i have a nt sierra with the 1.6 efi swap and my starter motor clicks alot before it finally starts sometimes it doesn't click at all and i have to clutch start it, i bought a vitara starter thinking this would be the correct one but it is to big in size..
someone told me i can grind part of the housing and make it fit, is this true??
what type of starter should i be looking for? and where do i find one??
Post Posted: Fri May 14, 2010 9:45 am
http://www.suzistore.com.au/shopexd.asp?id=1719
You need one of them..
Either that or grind bit's off your block or the starter you just got.. 8O
Post Posted: Fri May 14, 2010 9:55 am
Can you go without it for a day???
Give it to me and let me see what I can do for you
Post Posted: Fri May 14, 2010 10:30 am
yeah i just picked up a new daily so i can go without for a day, when would suit?
Vehicle: Jeep
Post Posted: Fri May 14, 2010 3:01 pm
You got the Sierra clicky starter syndrome... even my Vit caught it... he he...
There is a 40cm length of multi plugin wires that go from the key barrel, to the firewall, apparently, the starter wire in it breaks down, and you get bad contact, hence the clicky starter... :wink: :lol:
Post Posted: Fri May 14, 2010 3:10 pm
ah really? it is very temperamental and sometimes it just kicks over first time for a while.
so just try re-wire hey?
Post Posted: Fri May 14, 2010 9:22 pm
It's worth a go, but by the sound's of it yours is dead...
If you put a relay on it you may get another month out of it, could be a cheaper option for now.
Post Posted: Sat May 15, 2010 7:02 am
put relay on it today and it works a treat....
Users browsing this forum: Google [Bot] and 467 guests
