It is currently Sun Oct 25, 2026 4:19 pm
Post Posted: Mon May 17, 2010 9:27 am
So after installing my extended shocks, WT diffs and 2" lift (Which was more like 3" considering my old springs were flat)
I have noticed some flex issues, it seems to flex about the same amount it used to.. But i would have expected SO much more flex considering the huge amount of travel range avaliable
Is it possible my springs are too hard? If so is there an easy fix to achieve more flex?
Like i can put a trolley jack under the front left spring, jack it up.. And the front right wheel will also leave the ground long before the left side is even close to the bumpstop
I almost had another rollover today, because i had two wheels off the ground, and my muddies dug a huge hole for me to fall into
Luckily i had a friend to counterweight the car and we were able to get out ><
Any help/tips/advice? Thanks guys
Post Posted: Mon May 17, 2010 9:30 am
Remove the load leaf
Post Posted: Mon May 17, 2010 9:31 am
Rusho81 wrote:
Remove the load spring
Sorry, don't understand what you mean
Post Posted: Mon May 17, 2010 9:35 am
niether do we....post up pics or specs........
did you keep the longer shackles on it?.....if so thats half your problem.
Vehicle: lj81 stockman
Post Posted: Mon May 17, 2010 9:37 am
the thick leaf
the wobble rocks
Post Posted: Mon May 17, 2010 9:38 am
Leaf thingy, isn't that what leaf spring owners do?? The smaller leaf at the bottom of the cluster :oops: :oops: Search posts by 'choppy', he did something similar
Post Posted: Mon May 17, 2010 9:41 am
Search function found this :roll:
http://www.auszookers.com/index.php?nam ... light=flex
Post Posted: Mon May 17, 2010 9:43 am
It has the stock shackles, with 2" lifted springs
The spring shackle angle on both front and rear is roughly perpendicular to the ground
What other info do you need? I don't think pics will help..
Post Posted: Mon May 17, 2010 9:46 am
weight of car.....brand of gear........etc.....etc..........
Post Posted: Mon May 17, 2010 9:50 am
Weight wouldn't be much different from stock
The boxes are all in the shed, will go check~
After reading that thread, it seems like i should remove 1 leaf from the front, and 2 from the back
Also is it possible i overtightened the bushes on the shackles? Would that restrict movement?
Post Posted: Mon May 17, 2010 10:12 am
so what you are saying the shackles are VERTICAL, if so that is your problem.
Post Posted: Mon May 17, 2010 10:16 am
They are vertical yes.. Why is this a problem and how do i fix it? :D
I may seem like i know things, but really it's a front.. I have no clue ><
Post Posted: Mon May 17, 2010 10:19 am
The load leaf is the flat one at the bottom on the rears. If you take any of the arched leaves out you'll lower the ride height. There are tapering techniques you can do to the end of each leaf which reduces friction. Shock length could be an issue, the extended length may be right but maybe they don't compress enough.
Let the springs settle they will come down a bit then if ya still not happy take some leaves out
Post Posted: Mon May 17, 2010 10:20 am
So, drive it like i stole/hired it for the next few weeks and it should fix itself we hope?
Post Posted: Mon May 17, 2010 10:26 am
we clearly know it's a front... we've seen what you've done to the zook. :wink: :lol:
if the shackle is vertical there is no room for any droop as it's alreay drooped as far as it can go. sounds like you got springs from 4wd Systems or some other dodgy spring maker.
Post Posted: Mon May 17, 2010 10:27 am
Yeah if ya wana put it like that :P
Post Posted: Mon May 17, 2010 10:30 am
Thanks Atari, lol
Well from the way i understand how a leaf spring works, having a vertical shackle isn't really a huge leverage issue upward.. But would cause one downward
Is there any quick/easy fix?
Or a crazy expensive/complex one perhaps haha?
Users browsing this forum: No registered users and 123 guests
