It is currently Fri Oct 30, 2026 4:21 am
Post Posted: Mon May 17, 2010 9:45 am
Hi guys,
My drums have been machined beyond max diameter and my shoes take two pumps to reach them, AND the adjusters are wound right out.
So, I need to find me some new drums.
ACT's most reputable brake shop cannot source any new replacements.
I've found some on ebay, but the postage from the US is $100+.
Have any of you guys sourced some locally?
Last edited by mightyrollaman on Mon May 17, 2010 10:42 am, edited 1 time in total.
Post Posted: Mon May 17, 2010 9:49 am
Give this a go
http://www.suzistore.com.au/shopdisplay ... asp?page=2
Post Posted: Mon May 17, 2010 10:39 am
Thanks Rusho,
They have a listing under W/T, but not N/T.
I thought these were interchangeable. Do you guys know better?
Post Posted: Mon May 17, 2010 10:43 am
rda might do em
As far as I know thay are, I'm sure I've swapped em round in the past.
Post Posted: Mon May 17, 2010 11:34 am
If all else fails try some oversize shoes
Vehicle: '94 suzuki maruti
Post Posted: Mon May 17, 2010 2:56 pm
or disk brake conversion... anyone know how much that would cost to get professionally done?
Post Posted: Fri Sep 03, 2010 6:35 am
Draging this up cause im also keen to convert my rear hub brakes to disks
does anyone know of a conversion kit or possibly swapping parts from a different model. i am currently swapping diff's from SJ40T N/T to SJ50 W/T.
Any help would be great
Thanks
Post Posted: Fri Sep 03, 2010 6:40 am
Thanks
BenT has a kit in research stages i think. Other than that lowrange and places like that do kits,but very few if any incorporate the sierra standard h/brake leaver.
Post Posted: Fri Sep 03, 2010 7:33 am
THe BenT kit is supposedly nearly done. He said a couple of weeks about a month ago...
Post Posted: Fri Sep 03, 2010 7:37 am
joeblow does a rear disk brake kit......
or so he says.......... :?
Post Posted: Sat Sep 04, 2010 7:44 am
Thanks heaps for the replys guys, Not to worried about the hand brake, as mine already has a transfer hand brake. Has anyone try'd a conversion kit from lowrange. Thanks again for any help
Post Posted: Sat Sep 04, 2010 8:03 am
Thanks
i have a benT rear disc kit and will be installing it in a few weeks. i will do a write up when i do.
from memory the kit was $240 and i also bought a good adjustable proportioning valve for $85. :wink:
Post Posted: Mon Sep 06, 2010 3:49 am
Sweet thanks heaps Shep i'll keep an eye out for it.
Does the kit only work with a certain year/model of calipers and disk or can you use any model sierras or vits?
Sorry for all the questions
Post Posted: Mon Sep 06, 2010 4:40 am
i reckon that it would work on any 1.3 leaf model.
mine is a 85 1.3 lwb with 89 wt diffs and the trans case is out of a 96 wt. :lol:
i plan to run sierra discs and calipers on all four wheels with a adjustable prop valve
and (thanks to wants33) a trans mounted hand brake. :lol:
i just have to pick up some bits next time i am in town and then i can install the kit.
Post Posted: Mon Sep 06, 2010 5:05 am
Sorry Shep i think i explained it wrong, i looked on the lowrange web site and they supply a kit "Trail Tough Economy Disk Brake Kit" to change the rears to disk but dont supply the calipers or disks. i havent seen the benT or know how to find it, but was wondering what model sierra or possibly vit, i need to find to get a set of calipers off to complete the conversion.
Thanks again
Post Posted: Mon Sep 06, 2010 5:13 am
benT is a kiwi fella that makes great stuff for suzukis and because kiwiland is
a thirdworld country the stuff is really cheap.
http://www.auszookers.com/index.php?nam ... rofile=625
with his kit ya just use sierra front discs and calipers but ya can fit them on the rear.
some model sierras will need the hand brake fitted to the trans case because
some have it on the rear wheels which ya loose when going to discs.
basically if you have WT diffs you will need to source a NT trans case handbrake, luckily it is a straight bolt on.
Users browsing this forum: Google [Bot] and 551 guests
