It is currently Tue Oct 27, 2026 2:39 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
Post Posted: Tue May 18, 2010 11:12 am
i want to put discs on the rear of my sierra. i dont care about the legalities of it
however i do want to be able to safely stop. 8O
what kits are available that work?
Post Posted: Tue May 18, 2010 11:43 am
pirate 4x4 link - stanza brake conversion
hope it helps shep
Think before you post to make AZ a better place :)
Post Posted: Tue May 18, 2010 8:25 pm
I personally wouldn't mind knowing about the legalities of it. I was looking at doing it a few months ago, but its been put on the backburner for a while...
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Tue May 18, 2010 8:42 pm
Snake Racing do a kit, word on da street is dat day are mad expensive though. lol.
Post Posted: Tue May 18, 2010 8:55 pm
you can redrill and weld the standard front caliper mounts to slip on the back and it all lines up if you face down the front of the drum about 1.5mmm dodgy but worked for me for years
Post Posted: Tue May 18, 2010 9:04 pm
Joeblow make's them to suite pintara rear caliper's so you can keep your hand brake . :wink:
And they are engineerable (in Vic).
Post Posted: Tue May 18, 2010 9:57 pm
Post Posted: Tue May 18, 2010 11:36 pm
SuziBlu wrote:
Im not going to worry about disc rear end, have been told by the brake people this combo will out perform any road test required by gov.
This conversion is normally done for ease of simplicity and they don't need to be replaced as often as shoes on a 4wd. Its not mainly used for better braking.
Disc pads are easier to replace than Drum shoes.
For mud, Discs braking last than longer shoes in a drum, because mud normally gets in the drum, and sands the shoes away as it can't get out.
Another option is clean the drum every mud bash. But alot can't be bothered, like myself..
Discs and pads self clean.
If i was keeping suzuki diffs, i would be considering a disc conversion.
Post Posted: Tue May 18, 2010 11:44 pm
Yea I can dig that, but as I will never take my suzi into mud, if I can at all help it, its just about braking ability for me.
As the fronts typically have 70% braking force, the cost of upgrading to discs for the rear for braking only, seems high, for ease of maintenance, yea, discs every time.
Vehicle: 1993 Sierra 1.6 efi Vit motor,
Post Posted: Tue May 18, 2010 11:53 pm
I'm putting R31 calipers on my Zook, with Sierra rotors.
Here are some photos of setup in progress -
Adventure before Dementia
Post Posted: Wed May 19, 2010 12:22 am
i thought about joe's kits but i have a trans mounted hand brake and pintara's aren't that common here. :lol:
i only want discs as i have just worn out my second set of shoes since i put the wt diffs in my car last October. unfortunately i have to drive through mud to get to the local shop.
Post Posted: Wed May 19, 2010 12:38 am
http://72.34.32.141/~snakerac/product_i ... 45587dfc7d
This is what you want if you want to keep Sierra rotors + calipers. The snake racing kit is rather expensive though... It works well though.
This is what I have on mine with a transfer mounted handbrake and a combination of WT and NT driveshaft (which I would guess is exactly what Shep is running)
It is a bit too biased towards the back but this can be rectified with a proportioning valve.
Alternatively http://www.lowrangeoffroad.com/index.ph ... rakes.html
Post Posted: Wed May 19, 2010 2:43 am
i had discs all round on my jimny, got it mod plated no trouble- it does need a bias adjuster though because it was a bit like ripping the handbrake up when i stomped on the brakes.
also- vented LWB vitara front brakes would assist the front end in stopping better
Post Posted: Wed May 19, 2010 6:12 am
Also known as a Pintara. :roll:
Post Posted: Wed May 19, 2010 7:58 am
Thats some nasty welds
edit: ive picked up a kit from the states to install subaru calipers on the rear. however i am currently undecided if i should install it or not.
Post Posted: Wed May 19, 2010 8:30 am
Have you found the correct calipers yet? They are quite hard to find over here in oz.
Post Posted: Wed May 19, 2010 8:34 am
Yes, but need to go and get them.
Vehicle: SJ80
Post Posted: Wed May 19, 2010 8:59 am
Arn't Skyline rear brakes the same as Pintara's?
Skylines are very very common.
Post Posted: Wed May 19, 2010 9:03 am
not here they aren't. :lol:
Vehicle: SJ80
Post Posted: Wed May 19, 2010 3:43 pm
Can't get some sent accross from the local Darwin wrecker?
Good old Australia Post?
Believe those R31 brakes stayed the same across a lot of different year models of skylines?
Post Posted: Thu May 20, 2010 6:49 am
the welds will probably still hold, I'm curious as to the grade of those bolts holding the adapter plate on?
Post Posted: Thu May 20, 2010 8:13 am
& how you have mounted the rotor??
Post Posted: Thu May 20, 2010 9:30 am
soon to be delivered to a few of our members...........
oh....and notice the welds on that spring perch....... :wink:
Post Posted: Thu May 20, 2010 10:29 am
Yep, thay on the wrong side mate.. :roll:
Is that the pintara caliper kit?? how much are you selling em for??
Post Posted: Thu May 20, 2010 10:45 am
Always quality work Joe.
Joes gear makes the american made kits look ordinary.
Post Posted: Thu May 20, 2010 10:53 am
Yes it does..
Post Posted: Thu May 20, 2010 12:06 pm
thanks joe, however all i see is 3 bits of lazer cut plate :D is that for the mitsi
calipers? what do ya do for a disk? and how does it all fit together?
Post Posted: Thu May 20, 2010 12:19 pm
Shep
I think damo did a write up recently of his install (slightly modified) of Joes set up.
The disk is the sierra front disk.
The plate for axle to wheel studs etc, from memory was cut by joe too, or the drum can be machined down. EDIT: I was wrong, not part of the kit
And yes it uses the pintara calipers and cradles.
Little bit of pissing around with the brakelines and brakeline brackets, but it looks the goods.
EDIT: linky to damos write up http://auszookers.com/index.php?name=Fo ... pic&t=3797
Post Posted: Thu May 20, 2010 12:23 pm
Delivered??? I'm still waiting on a reply to a PM from a couple of months ago!! $$$ waiting.
Post Posted: Thu May 20, 2010 12:29 pm
jdk81 wrote:
Shep
And also a link to Joeblow's thread on these brackets.
Users browsing this forum: No registered users and 239 guests
