It is currently Tue Aug 04, 2026 11:31 pm
Post Posted: Thu May 20, 2010 10:15 am
Car: 90' Sierra
My right headlight is only receiving 6v. (normally it should be 11v-12v) I've gone over all connections (unpluging, cleaning, repluging) but all seems fine. Even though the bulb was 100% I replaced it for good measure but to no avail. Fuses are all okay. I've spent 3 hours going over it and cannot for the life of me figure out what it could be. I'm thinking of taking it to an auto-lekky to share the pain. Any suggestions as to what it could be?
Cheers,
Jimmy
Post Posted: Thu May 20, 2010 10:17 am
you wil find 2 fuses for the headlights..
one for the left and one for the right.. one of the fuses is blown.
Post Posted: Thu May 20, 2010 10:19 am
does the highbeam light on the dash stay on too?
Post Posted: Thu May 20, 2010 10:27 am
& if it does??? :?
Vehicle: jimny
Post Posted: Thu May 20, 2010 10:29 am
& if it does??? :?
you will have a blue light on!!
Post Posted: Thu May 20, 2010 10:30 am
Yes and actually pull these fuses out and check because they will test fine with a light even though 1 is blown. - draws current from otherside.
Post Posted: Thu May 20, 2010 10:36 am
Two fuses 8O :oops:
Are they both located in the fuse box in the drivers foot well?
(High beam dash lighht functions normally)
Post Posted: Thu May 20, 2010 10:45 am
& if it does??? :?
when the tail light fuse blows the high beam light comes on on low beam and the drivers headlight comes on dim, got me buggered how, I tend to see how electricity works but cant figure this out
Post Posted: Thu May 20, 2010 10:51 am
& if it does??? :?
That's a good one. 8O :?
must try to draw current through the high beam circuit.
Post Posted: Thu May 20, 2010 11:05 am
Red_October wrote:
Two fuses 8O :oops:
yeh they should be next to each other
Post Posted: Thu May 20, 2010 12:24 pm
& if it does??? :?
I noticed this before... Got an electrical engineering degree but its got me buggered too...
I want my old sig back :(
Vehicle: SJ80
Post Posted: Fri May 21, 2010 3:46 am
Another vote for the head light fuse. Had the same problem, one headlight would be bright for a second then go dim. One fuse was knackered, took me a little while to suss it out too!
Post Posted: Sat May 22, 2010 7:43 am
Yup, it was a blown fuse. It had such a small crack that I missed it the first time. Thanks for everyones advice :P
Post Posted: Thu Nov 17, 2011 2:08 am
Can someone please inform me where the fuses are located for the L/R headlights? I'm having all sorts of troubles. The passenger side parkers work, but no response from normal and high beam. Thanks in advance.
Post Posted: Thu Nov 17, 2011 2:17 am
they are towards the top left side of the 2 rows
if you have no lights at all you could look at the dip switch too, specifically the earth from teh column
Users browsing this forum: No registered users and 286 guests
