It is currently Tue Oct 27, 2026 1:11 am
Vehicle: 6.5s, gti, 31 extremes
Post Posted: Mon May 24, 2010 1:57 pm
can i fit jimny springs into a sierra coily, if i was to modify front shocks?
Post Posted: Mon May 24, 2010 2:26 pm
Most probably, Got a tape measure?
I have Jimny springs out. I can measure them tomorrow morning for you when i get up.
Post Posted: Mon May 24, 2010 7:05 pm
Front struts.....if you are thinking mega lift springs keep in mind it is really difficult to find struts that are longer than 50mm from
standard. Your only options would be custom struts which would be really costly, or put the jimny type suspension mounts(shock and spring)which would also be a costly event if you had to get someone to do the work. Search for 'trogdor 2' saam's old rig. He did this type of setup. Had about 5 inches of lift from standard. Hope that helps
I think the jimny springs will fit also 8)
Post Posted: Tue May 25, 2010 12:20 am
Zookimonsta has 80mm lifted Jimmy shocks and I think springs in the rear?
Users browsing this forum: Google [Bot] and 329 guests
