Print view
Previous topic | Next topic
| Author |
Message |
lordfury007
Joined: Mon Sep 28, 2009 11:30 pm Posts: 298 Location: Darwin, NT
 Posted: Mon May 24, 2010 9:55 am |
How does "Plus" ULP rate?
http://www.unitedpetroleum.com.au/index.asp?pgID=66
I had been using it on my 2000 GV and now am running it on my 88 Sierra (with G16A EFI) without any problems.
I've always thought the higher octane rating (95 Octane) compared to the usual 91 was a good thing, and the 10% ethanol wouldn't hurt the engine, but i could be wrong.
_________________ 1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
MacDaddy
Joined: Thu Mar 26, 2009 10:30 pm Posts: 10453 Location: Perth, Australia
Vehicle: Jeep
 Posted: Mon May 24, 2010 5:07 pm |
lordfury007 wrote: How does "Plus" ULP rate? http://www.unitedpetroleum.com.au/index.asp?pgID=66 I had been using it on my 2000 GV and now am running it on my 88 Sierra (with G16A EFI) without any problems. I've always thought the higher octane rating (95 Octane) compared to the usual 91 was a good thing, and the 10% ethanol wouldn't hurt the engine, but i could be wrong.
Yes Plus/Premium ULP is much better, its all i use now... it has alot less additives than standard UL, which contains alot of Sulpher, hence the rotten egg smell you can get sometimes with just standard UL, just makes the engine run dirty, the Zook engine, i believe, was designed to run on the higher ( 95 Octane ) fuel, so using a 91 Octane UL, is just less than a Zook deserves...
So do you use E10 in your Zook now ?
lordfury007
 Posted: Mon May 24, 2010 8:01 pm |
Well, considering the PLUS ULP is cheaper than standard ULP (2c/Litre due to government subsidy) at least here in darwin, yeah its all i use.
Not that i'm worried about 2c/litre, but if the car likes it, why not?
royce
 Posted: Mon May 24, 2010 8:33 pm |
MacBear wrote: lordfury007 wrote: How does "Plus" ULP rate? http://www.unitedpetroleum.com.au/index.asp?pgID=66 I had been using it on my 2000 GV and now am running it on my 88 Sierra (with G16A EFI) without any problems. I've always thought the higher octane rating (95 Octane) compared to the usual 91 was a good thing, and the 10% ethanol wouldn't hurt the engine, but i could be wrong. Yes Plus/Premium ULP is much better, its all i use now... it has alot less additives than standard UL, which contains alot of Sulpher, hence the rotten egg smell you can get sometimes with just standard UL, just makes the engine run dirty, the Zook engine, i believe, was designed to run on the higher ( 95 Octane ) fuel, so using a 91 Octane UL, is just less than a Zook deserves... So do you use E10 in your Zook now ?
Rotten egg smell is cause your cat converter is buggered and is now pumping out cancer causing toxins that kill kittens amd medium size birds
Sulfur is in oil to lubricate slidy stuff, gas oil has more of it too
MacDaddy
Vehicle: Jeep
 Posted: Tue May 25, 2010 5:20 am |
royce wrote: MacBear wrote: lordfury007 wrote: How does "Plus" ULP rate? http://www.unitedpetroleum.com.au/index.asp?pgID=66 I had been using it on my 2000 GV and now am running it on my 88 Sierra (with G16A EFI) without any problems. I've always thought the higher octane rating (95 Octane) compared to the usual 91 was a good thing, and the 10% ethanol wouldn't hurt the engine, but i could be wrong. Yes Plus/Premium ULP is much better, its all i use now... it has alot less additives than standard UL, which contains alot of Sulpher, hence the rotten egg smell you can get sometimes with just standard UL, just makes the engine run dirty, the Zook engine, i believe, was designed to run on the higher ( 95 Octane ) fuel, so using a 91 Octane UL, is just less than a Zook deserves... So do you use E10 in your Zook now ?  Rotten egg smell is cause your car converter is buggered and is now pumping out cancer causing toxins that kill kittens amd medium size birds Sulfur is in oil to lubricate slidy stuff, gas oil has more of it too
Ha ha... nahhh my Caty is fine... i meant when following some cars, or when another car has passed, you can sometimes smell that rotten egg Sulfur smell... oh so thats what it is, their Caty has given up...
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Tue May 25, 2010 6:18 am |
You can get this pong from really new cars, sukx hey.
_________________ Bad decisions make good stories.
Users browsing this forum: No registered users and 311 guests
