It is currently Tue Jul 28, 2026 4:11 pm
Post Posted: Tue May 25, 2010 8:01 am
Just checking what everyone has done as the calmini instructions are poo!
Is this the way the bushes go? I think this way.
It says you dont need the sleeve, which i assume is the crush tube but if you dont it doesnt centre the new calmini bush as it has a large centre hole.
And if you use the sleeve its too long for the bush thickness, so maybe a bit cut off would be good.
Thanks
Post Posted: Tue May 25, 2010 8:08 am
uncle chop chop says chop ya sleeve...
are you going to beat buckets installation record?
Post Posted: Tue May 25, 2010 8:13 am
So thats the way the bushes go?
Depends, i have alot of work on at the moment. Passenger side front is done, and before i start to strip the drivers side and dfading light i decided to change the diff brackets.
Fark me the bolts were corroded to the diff on that centre bracket. 8O
Post Posted: Tue May 25, 2010 8:25 am
sorry, the photo didn't load the first time... :oops:
yeah, you have the it the right way.
Vehicle: SJ50 hardtop!
Post Posted: Wed May 26, 2010 12:59 pm
This makes me hope I have put mine in the right way.
And who knew you could take the whole thing out? I did it the bloody hard way and took the bolt out of the top instead of taking the whole unit out!
NT SJ50
Post Posted: Wed May 26, 2010 1:04 pm
so you didn't see the two holes in the bottom of the cross member & the bolts holding it on?
Post Posted: Wed May 26, 2010 1:06 pm
Nope. It wasn't until I started on the rear end and actually had a read through the service manual that I found you could take it out that way.
NT SJ50
Post Posted: Wed May 26, 2010 8:30 pm
The idea of replacing the bush is to assist in the lowering of the diff - the supplied bush is smaller than the rubber OEM one and goes agaist the cross member, so you have it right .... But my instructions clearly state to cut the crush tube to fit ! - Your kit looks like the 3", mine was the 2" sa I had the replacement bush you show, but it went on the standard diff bracket. How are your rear shocks ? - I had to replace mine as they where too short (although Calmini refused to agreee) .. Ended up replaing with OME rears intended for a 40mm lift and they are now great.. I actually have some articulation!!!
Post Posted: Thu May 27, 2010 10:32 am
Haha Bucket, yes it comes out and rather easily too :wink:
ozhum, my instructions say " you dont need the sleeve" ut their new bottom bush has a hole in it the size of the sleeve and if you dont put it in it is sloppy :roll:
Post Posted: Thu May 27, 2010 10:54 am
We put the sleeve in mine and we had to cut a bit off it from what i remember :roll:
Post Posted: Thu May 27, 2010 10:58 am
All the holes on the diff drop brackets were far too large. Tried sleeving but then the holes didn't match up to the diff.
NT SJ50
Post Posted: Thu May 27, 2010 11:08 am
Bucket, we're talking about the steel sleeve that came out of the standard pinion bracket.
yeah the bolt holes on the calmini brackets are sloppy...
Post Posted: Thu May 27, 2010 11:12 am
Oh yeah, i know that. I just thought I'd throw the "holes too big" out there too :p
I think I reused the sleeve in mine.
NT SJ50
Post Posted: Fri May 28, 2010 1:56 am
DOHHHHHH!
NT SJ50
Users browsing this forum: Brenno, Google [Bot] and 327 guests
