It is currently Wed Jul 29, 2026 1:50 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
Post Posted: Fri May 28, 2010 7:26 am
DMAC wrote:
OK I have spark but now it won't rev without missing like crazy over 3000 rpm.
I have set the timing as per spec 8 degrees BTDC at 850 rpm. Timing mark advances when revved so I assume vacuum advance is working OK.
I'm a lttle dubious about the exchange module. As far as I'm concerned its 1 tooth out from where it should be. This also being the only thing I've altered.
Anymore suggestions? :?
In the wise word's of a racist ranger, "Please explain?"
Do you mean the dizzy? If so how did you set it to 8deg?
Post Posted: Fri May 28, 2010 7:40 am
I have taken pictures of where the rotor sits at TDC previously.
Just left of the dizzy adjustment locking screw I have had to rotate the rotor 1 tooth clockwise to get it to run. I put it down to being a different module possibly having different lag charateristcs in the electronics.
SS
Post Posted: Fri May 28, 2010 7:47 am
Your a notch out. :roll:
Blubby Electrician's. :lol: :lol: :lol:
Post Posted: Fri May 28, 2010 8:18 am
I just remembered that you have a big cam, do you know what size/grind it is??
You may need to knock your timing up to 10 or even 12deg depending on the size of the cam..
Post Posted: Fri May 28, 2010 9:56 am
Yep MASSIVE. :rambo: pompoms
20/60 Nothing on the specs about timing just valve clearances.
Going to try and sort it with Jas tomorrow.
SS
Post Posted: Fri May 28, 2010 10:00 am
20/60's only a baby, I'd still be running 10 tho, you should notice a diffrence.
So you wheeling tomorra?
Post Posted: Fri May 28, 2010 10:10 am
if the timing is correct then the teeth are right, might sit a bit different in the housing but the timing mark is the relation with teh dissy pickups to crank, you cant be out by a tooth and it still line up
if its missing at revs and not load dependent then its either not heatsinked properly or probably buggered, ive had a new module do this before, was annoying to try and figure
Post Posted: Fri May 28, 2010 10:17 am
Yep thats where logic has taken me too. Hopefully a switch aroony before we wheel tomorrow will confirm this.
Glasshouse.
SS
Post Posted: Sun Jul 18, 2010 7:55 am
:evil: :evil: :evil: :evil: :evil: :evil:
Can't believe it has happened again. Luckily only 6 km from home.
Need to confirm fully, but excactly the same symptoms as before.
Looks like another trip to the SSCSW. :wink:
Has anyone installed an aftermarket ignition system?
SS
Users browsing this forum: No registered users and 379 guests
