It is currently Tue Oct 27, 2026 12:13 pm
Post Posted: Sun May 30, 2010 1:02 pm
just took the zook for a first long trip as we started noticing that it would cut out when you come to a stop or on low rpm?? any one know what the problem is??
Vehicle: 1995 Sierra 1.3
Post Posted: Sun May 30, 2010 2:03 pm
Vehicle: 93 Sierra
Post Posted: Sun May 30, 2010 2:47 pm
Or another technique (easier because you don't have to pull the intake snorkle off) is to turn the engine off, swap leads 2 & 3 over, fire it up again and rev it to no more than 2500rpm for about 15 secs. It should backfire a couple of times - once it has, foot off the accelerator again and see if it idles properly. If it does, swap your leads back over and you're done. If it doesn't try another couple of backfires.
Swapping the leads gets the spark plugs in cylinders 2 and 3 firing on the intake stroke - the flame front goes all the way up the intake runners into the carby and (with luck) burns out the crap that's in the idle jet.
Works 95% of the time in my experience ;)
Post Posted: Mon May 31, 2010 12:50 am
^^ I've used both methods and both work fine.
Moph, you lazy bugger, there's only one nut to take the carby hat off.
Vehicle: 93 Sierra
Post Posted: Mon May 31, 2010 1:47 am
You know me so well :lol:
Users browsing this forum: Google [Bot] and 181 guests
