It is currently Sun Oct 18, 2026 10:20 am
Post Posted: Thu Jul 20, 2006 12:29 pm
Does anyone know if you can adjust a sierra clutch without
having to pull it apart?
The land rovers can be adjusted from outside the housing.
(sorry, had to mention those other types of 4x4) :oops:
96 soft top
keep 2 on the ground
Post Posted: Thu Jul 20, 2006 12:39 pm
yep easy as, on the drivers side of the gearbox is the big arm that operates the throwout bearing, on the end of the cable there is an adjuster nut, loosening will make the clutch 'bite' lower down the pedal, tightening will make it higher.
just be careful you dont go to tight, you need some freeplay in that arm so the throwout bearing doesnt burn out
we might have to get some virtual kitty litter so all those landrover words dont leak oil over the forum :oops:
Post Posted: Thu Jul 20, 2006 2:39 pm
sounds like tech to me.
you can also buy new cables from ebay for $40 if yours is too stretched to get good adjustment out of.
has anyone tried the non-genuine cables? are they ok? is it much more expensive for genuine?
'your eyes look glassy, have you been drinking?'
Post Posted: Thu Jul 20, 2006 3:03 pm
I had a non genuine one in my 1 litre and was no problem, I would reckon it would cost $40 for the packaging for a genuine one :wink:
Vehicle: 1994 Hard Top Sierra
Post Posted: Thu Jul 20, 2006 8:20 pm
Moved to techy talk :wink:
Jason
Navigator for Team Casper
Post Posted: Fri Jul 21, 2006 3:05 am
Thanks casper, us forum virgins need some help :oops:
& thanks for the tips, more to follow. :)
96 soft top
Users browsing this forum: Google [Bot] and 316 guests
