It is currently Tue Oct 27, 2026 4:10 pm
Post Posted: Tue Jun 15, 2010 12:36 am
The inlet manifold on my Sierra has a brass fitting where the heater hose??? connects and it is badly corroded, it looks like it is pressed in, are these parts available as a replacement and if so how hard are they to replace?
Post Posted: Tue Jun 15, 2010 1:35 am
I don't know if this is of any help to you but there is a perfectly good inlet manifold at the chandler refuse centre that I accidently chucked out 2 weeks ago.....
 Profile WWW ICQ YIM
Post Posted: Tue Jun 15, 2010 1:44 am
I don't know of any replacement parts for this. Either get another manifold, or take yours to a machinist and get them to make a new brass pipe.
Post Posted: Tue Jun 15, 2010 10:04 am
had a similar problem on a bmw the other day..
i removed the press in pipe. and tapped the whole and fitted a bew brass fitting that screws in.
worked a treat.
Post Posted: Tue Jun 15, 2010 3:41 pm
Thanks all for your help, looks like I will have to chase up a manifold if the bodgy job I did on it doesn't hold!
Vehicle: '92 Sierra
Post Posted: Tue Jun 15, 2010 9:32 pm
You can look out for a G16A 8 valve manifold too. I reckon what 89 posted above sounds like a great idea though.
Post Posted: Tue Jun 15, 2010 11:04 pm
worked a treat.
What sized tap was it?? Would have been a decent size?
Post Posted: Wed Jun 16, 2010 3:11 am
The longer you leave it, the more rubbish you're gonna have to sift through at Chandler dump....
...again.... I hope this helps
 Profile WWW ICQ YIM
Users browsing this forum: No registered users and 263 guests
