It is currently Thu Oct 29, 2026 1:17 am
Vehicle: MY2019 Jimny
Post Posted: Fri Jun 18, 2010 7:20 am
Has anyone seen these before?
They are a rubber bump stop that goes on the shaft of your shock absorber - I was wondering if they would be any worse than regular bump stops.
http://www.rocky-road.com/zukevs.html
Post Posted: Fri Jun 18, 2010 7:31 am
major problem i see with those is you loose a fair bit of compression. so you will need shock towers and longer shock to get the same amount of travel.
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Post Posted: Fri Jun 18, 2010 7:32 am
Yes, they are much worse.
Shock mounts aren't designed for the force a bump stop is intended for. Additionally, bumpstops don't really want to be where the shocks are- there's different requirements of the geometry.
Post Posted: Fri Jun 18, 2010 7:35 am
Not a new idea, But i haven't seen it on cars. I suppose if all your shock mounts are strong and the shock welds are good it should work. I think on a harsh bottom out you would snap mounts so easy though. Easy enough fix but little gain.
EDIT: I don't think you'd lose that much travel. You could just cut it to get it spot on so it absorbs before you bottom out. Exactly like a normal bumpstop. But yeh you would KILL your suspension.
Post Posted: Fri Jun 18, 2010 8:37 am
What thay said & would fill up with mud & shit, scratching the ram..
Post Posted: Fri Jun 18, 2010 12:31 pm
I asked Steve from Rocky Road what's better in his opinion, bumpstops on shocks or one mounted on axle/ chasis. He said that the ones on shocks put a lot of strain on shock mounts, so I guess it depends on your shockmounts. That's why I made bumpstops (you've seen them) and didn't buy those Rocky Road offers as alternative.
Post Posted: Fri Jun 18, 2010 1:34 pm
this is the opposite of what i need. i need a smaller closed shock length so the shock doesnt close before the bumpstop hits and damage the shock mounting points top and bottom.
Users browsing this forum: Google [Bot] and 469 guests
