It is currently Mon Oct 26, 2026 8:30 pm
Post Posted: Fri Jun 18, 2010 11:36 pm
hey fellas i have recently taking the carby off my suzuki sierra to replace the gasket between the caby nd template, i have made a gasket out of gasket paper but im not sure i made it properly as i destoyed the old one when getting it off. so just wondering if any one knows were i can find a pattern to see if its the same, oh and all so is there ment to be a gasket between the template and the manafold, because mine doesnt
thanks
Post Posted: Fri Jun 18, 2010 11:48 pm
thanks
Mate, It would be better to go purchase the 2 gaskets seriously thy're only a couple of dollars each and for the sake of acouple of dollars it is not worth the hassle.
David
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Fri Jun 18, 2010 11:53 pm
yea i know they are few dollars but i need to go some were and i didnt know were to get some from so i just quickly went and bought gasket paper so is there ment be a second gasket
Post Posted: Sat Jun 19, 2010 12:35 am
Yes one between the manifold and spacer and one between the spacer and carby base.
Make sure all holes air holes are not covered with gasket paper. or it won't run properly
David
Zuki
Now just drive i
Post Posted: Sat Jun 19, 2010 1:48 am
ok thanks that would be my problem why it runs shit lol
Post Posted: Sat Jun 19, 2010 7:57 am
does any one know how much a carby rebuild or to recon my carby would be
Post Posted: Sat Jun 19, 2010 10:45 am
Rebuild kits are about $60. You get everything you need to rebuild. Gaskets, accel pump, washers, needle and seat etc.
Repco, carbitz, bursons will usually stock them or point you in the right direction...
Post Posted: Sat Jun 19, 2010 10:46 am
Sorry, and rebuilds or exchanges by a pro will cost you around $400 I think..
Post Posted: Sat Jun 19, 2010 11:00 am
stuff that way out of my range, might source out a rebuild kit
Post Posted: Sat Jun 19, 2010 12:28 pm
Yeah mate it's a bit pricey. Just get a rebuild kit, download the manual and you should work it out. I knew Jack sh$t about carbies before the Sierra, - always had injected cars, but I've learnt valuable info from doing it myself. Also helps to know, especially if you breakdown out in the bush, you"ll have a general idea on where to start looking and quick fixes.
Post Posted: Sat Jun 19, 2010 9:52 pm
were is the best place to get the kit from
Post Posted: Sat Jun 19, 2010 10:41 pm
Post Posted: Sat Jun 19, 2010 11:34 pm
haha oops blonde moment :roll:
Users browsing this forum: No registered users and 148 guests
