It is currently Fri Oct 30, 2026 12:14 pm
Vehicle: MY2019 Jimny
Post Posted: Sun Jun 20, 2010 11:38 pm
What would cause a rear axle seal to prematurely fail in a Sierra?
Bent axle, worn axle, what else?
At the moment I am getting about 8-9 months out of a rear axle seal, which sux!
Post Posted: Sun Jun 20, 2010 11:46 pm
Most times premature failure is due to the way the axle was put back into the diff tube causing damage to the seal.
Post Posted: Sun Jun 20, 2010 11:49 pm
The way the seal was fitted, seal surface on the axle worn, bearing play?
I personally don't think aftermarket seals are any worse than genuine ones
Post Posted: Sun Jun 20, 2010 11:51 pm
Surface maybe, bearings are about a year old - mechanic is pretty good.
Post Posted: Sun Jun 20, 2010 11:53 pm
bent housing, leaking air locker.
Post Posted: Sun Jun 20, 2010 11:55 pm
Then just use Steves method of replacing everything till it's fixed :lol: :lol:
Yeah I am concerned it might be the housing - Airlocker isn't on enough for that to be it.
Post Posted: Mon Jun 21, 2010 1:03 am
Mud???
Post Posted: Mon Jun 21, 2010 1:09 am
Nope, not recently.
Has the axle been out with in the last say 3 weeks?
If it has then i would say the seal has been pinched, I have to replace mine as i nicked the seal when refitting my axe the other week and it is now weeping.
I would look at replacing the hub seal.
If it always happens what side does it happen on??
or is it both?
Post Posted: Mon Jun 21, 2010 1:16 am
It hasn't been out since the last time it was replaced, about 9 months ago.
Post Posted: Mon Jun 21, 2010 1:20 am
Is it one side all the time our both?
Post Posted: Mon Jun 21, 2010 2:20 am
Diff breather isn't blocked? causing the diff to pressurise?
Post Posted: Mon Jun 21, 2010 2:26 am
you get a year out of standard bearings?....thats pretty good.
Post Posted: Mon Jun 21, 2010 2:35 am
Passenger side more often I think
Post Posted: Mon Jun 21, 2010 2:36 am
breather is good, both sides would leak if it was blocked I reckon.
You serious?
Post Posted: Mon Jun 21, 2010 3:07 am
lump_a_charcoal wrote:
You serious?
x2!
Post Posted: Mon Jun 21, 2010 3:49 am
damaged/non existent splashguard inside the housing will cause more oil to reach the seal, increasing heat and wear and would be more likely to fail.
[quote="BlueSuzy"]
Simple story.
Like Kakadu
Vehicle: '94 suzuki maruti
Post Posted: Mon Jun 21, 2010 7:25 am
sorry to hijack thread, but ive had the same problemi have the diff centre out too at the moment, is it possible for someone to explain what these splash guards look like & where they're meant to be?? please :?: :D
Post Posted: Mon Jun 21, 2010 8:20 am
OK turns out it had some grit in it, which chewed the seal out a bit.
Post Posted: Mon Jun 21, 2010 11:08 pm
I have not ran a splash guard in my rhs since i did the seal. yonks ago.
I put the seal in, then, oh whats this doova? oh well. She'll be right, and she has! Don't ask me where it is now though..
Vehicle: Sierra
Post Posted: Tue Jun 22, 2010 11:00 pm
Mate and I get about 6months (max) for the rear wheel bearings, the seals get replaced then.
Seals can often go bad once excess play develops in the bearings.
Vehicle: '92 Sierra
Post Posted: Wed Jun 23, 2010 2:20 am
Why would it leak both sides if the breather was blocked? I would expect it to build up pressure until one side went then it would just vent via that one failed seal.
Water and mud was always the culprit back in my young/dumb/no breather extension days.
Post Posted: Wed Jun 23, 2010 9:13 am
Yes, good point. :oops:
Users browsing this forum: No registered users and 330 guests
