It is currently Fri Oct 30, 2026 8:13 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Vehicle: 02 GV
Post Posted: Sun Jun 20, 2010 7:22 am
okay, my battery went flat listening to the radio while installing my new tow bar. tried jump starting it but would only crank over but not start.
from looking at it all day i worked out the fuel pump is working, it doesn't have spark and not sure if the injectors are firing.
anyone have any ideas, or know of any good suzuki mechanics around brisbane northside.
thanks.
it's a 2002 2.5l v6
Post Posted: Sun Jun 20, 2010 7:49 am
Is there an imobilizer in the Vit that you don't know about? silly question I guess If ya don't know its there hey...
Vehicle: 02 GV
Post Posted: Sun Jun 20, 2010 8:23 am
don't think so, tried the differnt keys and had a good look under the dash.
Post Posted: Sun Jun 20, 2010 8:48 am
If auto is it in P or N and if so try moving the gear leaver as you try to start it.
Steve W
Vehicle: 02 GV
Post Posted: Sun Jun 20, 2010 9:56 am
nah can't be that, it does crank over and nothing when in any other position other the P or N.
Post Posted: Sun Jun 20, 2010 11:19 am
Thay do have, but the immob light or eng light should be flashing.
Do you have a test light? sound's to me like you have a blown fuse, & yes, from "jump starting it", you will need to check ALL fusses, if one is blown it could affect another part of the car.
If you have no blown fusses, go shout your self a NEW battery
I'm south side, but these car's are my living.. :P
Vehicle: 02 GV
Post Posted: Mon Jun 21, 2010 6:37 am
i've checked all fuses 10 times. i did put a good battery in.
how does the immobilser turn on and off. i've never thought it had one as i've never activatwed/deactivate it.
it's at ultra tune now, hopefully fixed under warranty. they think it's the crank angle sensor or the immobiliser.
Post Posted: Mon Jun 21, 2010 6:42 am
:shocked: mmm. 8O
Imob chip is in the key, & you don't turn it on or off, has a lil coil on the key barrel.
Post Posted: Mon Jun 21, 2010 6:56 am
sounds like the transponder key needs to be reprogramed to the ECU, any good automotive locksmith with a transponder computer should be able to do it.
Vehicle: 02 GV
Post Posted: Mon Jun 21, 2010 7:04 am
:shocked: mmm. 8O
i thought it would be like a commodore, for it to be like that, as in the key has a little metal bit that touches the car. I started using the spare keys about 5 days ago as the battery in the old keys when flat and was sick of opening the door with the key.
Post Posted: Mon Jun 21, 2010 8:25 am
Spare key should still start it, the battery only work the remote, when you turn the ing on, does any of the light's(apart from air bag) flash at you??
Vehicle: 02 GV
Post Posted: Mon Jun 21, 2010 9:31 am
the check engine light flashes, couldn't remember if it always did though untill the car was started.
Post Posted: Mon Jun 21, 2010 9:34 am
It's the imob, you either need a key re learn or new key's
Post Posted: Mon Jun 21, 2010 12:53 pm
:shocked: mmm. 8O .
You aren't implying that a large automotive franchise would take money off a customer dishonestly are you? 8O :P
Vehicle: 02 GV
Post Posted: Mon Jun 21, 2010 8:12 pm
it has a warrenty, so as long as it doesn't cost me money lol!!
with getting the key reset, who can do it, does it need to be suzuki, has it just lost the code in the car.
Vehicle: 02 GV
Post Posted: Tue Jun 22, 2010 8:12 am
update, at ultratune they finally got codes out of it but can't fix it. so was then towed to zupps suzuki.
codes are
P1623 - ECU code not matched and,
P1621 - Immobilser serial communication error.
hopefully easy fix now. already cost me $390 in towing and diagnostic fees.
Post Posted: Tue Jun 22, 2010 8:19 am
codes are
:P :P 8O 8O Code's are an awesome start, But with those 2 code's I have stripped the harness of an Xl7 to find ONE broken wire..
Hopefully it's just a re-learn.. :P
Post Posted: Tue Jun 22, 2010 1:35 pm
codes are
ummm, you do realise you could have got those code out of the ecu using a paper clip & 5 minutes of you time.... tell them to jam their diagnostic time where the sun don't shine if it's more than 1/2 an hour.
Vehicle: 02 GV
Post Posted: Wed Jun 23, 2010 8:12 am
codes are
yeah did the paper clip thing and only got code 12 - everything is A OK!!
i guess you need a tech 1 to get the codes.
Post Posted: Wed Jun 23, 2010 8:26 am
:? :? Didn't think it would let you into Immob on your car.
Tech 2 would..
Any new's????
Post Posted: Wed Jun 23, 2010 9:21 am
i have posted a bit of info on this over on nbs for the OP.
you cant get any codes other than fuel injection codes from the diagnostic socket.
there is another socket under the dash for manually downloading codes for immobiliser (and its not easy to find)
atari 4x4 , its not quite as simple as what you said , its a series of tests to eliminate any other problem , including wiring problems between the immobiliser and ecu , once you rule out everything else then you can safely say the problem either lies in the ecu or the immobiliser , it took me an hour and a half to do all the tests on another persons car with identical problem, so $120 in labour for diagnostic time .
they may have been steep because they dont know the car very well , or have all the information at hand to diagnose the problem quickly.
Post Posted: Wed Jun 23, 2010 9:24 am
^^^ Agree, after market wiring make's it harder some time's to, pulling power from place's that don't like it taken away..
Vehicle: 02 GV
Post Posted: Wed Jun 23, 2010 9:39 am
all the wiring is standard, hopefully find the problem tommorro.
Post Posted: Wed Jun 23, 2010 10:55 am
Sic, am keen to know what it was.
Post Posted: Wed Aug 04, 2010 6:43 pm
Hello, unbelievable the exact same thing happened to me .What did you do to fix it??I am real desperate
Vehicle: 02 GV
Post Posted: Thu Aug 05, 2010 6:13 am
it was a blown ecu, the immobilser circuit within the ecu. to zupps 2 weeks to work it out as it did look like the ecu but the actual immobilser. i ended up sourcing a second hand ecu as they wanted $3500 and had to wait 4 weeks for delivery.
Post Posted: Thu Aug 05, 2010 6:19 am
Some one reversed the polarity's while fitting the battery.. :roll:
Vehicle: 02 GV
Post Posted: Thu Aug 05, 2010 9:03 am
i honestly didn't, only tried to jump start start it with jumper cables that didn't have spike protection.
Post Posted: Thu Aug 05, 2010 5:25 pm
Thanks for the info bailey it now clarifies the problem for me,now the search begins for a new ecu.
Post Posted: Thu Aug 05, 2010 5:28 pm
Users browsing this forum: No registered users and 360 guests
