It is currently Thu Oct 29, 2026 4:44 am
Post Posted: Sun Jun 20, 2010 7:18 am
Hey guys,
I've seen alot of people putting earlier model swift and gti seats in sierra's so just wondering if the 06 ones would fit with as little modification? couldnt find the answer from searching.
Thanks
Post Posted: Sun Jun 20, 2010 11:22 am
Thay seem to be narrow enough, but if thay are from a S or Z badged thay will have side air bag's, no good to you....
Get a tape out & measure them, please tell how thay go tho.. :P
Thay are comfy..
Post Posted: Sun Jun 20, 2010 2:22 pm
i got 2007 swift seats in mine. bit of messing around and are a fraction wider than the stock ones but still fit....and really comfy
Post Posted: Tue Jun 22, 2010 8:20 am
What sort of messing around? It seems earlier ones are just drilling a couple more holes in the rails? What did you actually need to do to get the 07 seats to mount successfully? Thanks again
Post Posted: Tue Jun 22, 2010 9:30 am
one of the rails bolts up really easy, the other one is the prick. i just used a piece of 40mm flat bar and re-drilled some holes.
its just a case of getting ya new seats, stripping off the old rails, and stripping the rails of ya stock sierra seats, and then taking measurements between the 2. then off to bunnings to get some flat bar and the nuts and bolts ya need. Just take ya time and remember to measure the distance from the rails to the edge of ya seats, as you dont wanna get the rails all mounted to the seats, then find that the seats themselves rub on the B pillar or on the seat belt buckle.
Sorry dont have any pics of the fab, but heres one of what they look like after for inspiration
Post Posted: Tue Jun 22, 2010 10:49 am
Thanks mate they look really good, I think i'll get the seats this week and give it a crack on the weekend. I'll let you know i go.
Post Posted: Tue Jun 22, 2010 10:53 am
no worries
if ya get stuck drop me a pm
Post Posted: Tue Jun 22, 2010 11:12 am
8O 8O 8O
Please tell me you bought high tensile bolts!!
Post Posted: Wed Jun 23, 2010 9:13 am
8O 8O 8O
high tensile what??? 8O 8O 8O 8O
ha ha ha of coarse, i'm rough but i aint that rough :roll:
Post Posted: Wed Jun 23, 2010 10:11 am
cant recall ever seeing high tensile bolts at bunnings . i could be wrong though ..
Post Posted: Wed Jun 23, 2010 10:12 am
Champion blister packs are all Grade 8 and 8.8
Post Posted: Wed Jun 23, 2010 10:17 am
the ones i bought said they were high tensile....dunno really
what grade is high tensile?
good, means they are metric :)
Post Posted: Wed Jun 23, 2010 10:29 am
when i put the recaros in my vit, i just used fielders roof zips into a couple of blocks of 90 x 45 from underneath, then just tek screwed the original rails into the timber!... easy as, and solid as a rock :wink:
Go Hard, Trailer Home
Post Posted: Wed Jun 23, 2010 10:33 am
Until the termites get to it :P :D
Post Posted: Wed Jun 23, 2010 10:35 am
i did a bit of research, and most places seem to reccomend a grade of 8.8 as a minimum.
Post Posted: Wed Jun 23, 2010 10:41 am
really 'high tensile' isnt a term cause then you have to define what high means
8.8 is a grade, it is the most common form of bolt specced and is only applicable to metric bolts, its imperial equiv is GR5, there is also metric grade 4.6 (lower tensile) and 12 something (higher)
most bolts in a car are likely to be 4.6 in reality
Post Posted: Wed Jun 23, 2010 10:55 am
Metric can be bought in G8.8, G10.9 and G12.9 quite easily from most reputable bolt suppliers. Although the last 2 tend to be more available in SHCS (socket head caps screws) than anything else.
Post Posted: Sun Jul 04, 2010 10:40 am
Well got a chance to take a photo of the seats today here's what they look like
Post Posted: Sun Jul 04, 2010 10:53 am
if i ever got rid of my bucket seats i think id get a set of these they look so good
Post Posted: Sun Jul 04, 2010 11:10 am
good work mate :D
how did ya go fitting them, any dramas???
Post Posted: Mon Jul 05, 2010 1:34 am
8O 8O 8O
Its kinda an interesting one there as the piece of tin suzuki uses as the factory seat mounts on the tub would deffo rip out before any high tensile bolt shears.
Dan
Post Posted: Mon Jul 05, 2010 1:57 am
Geez those seats are close together. Do you and and the passenger knock elbows much?
2002 SWB GV
Lifted and Locked
Post Posted: Mon Jul 05, 2010 4:16 am
JrZook wrote:
8O 8O 8O
Dan
X2 Dan My swb had one cracked and the driverside inner rear was torn out completely. I had to cut a piece of plate for under each.
98 GV
Post Posted: Mon Jul 05, 2010 5:32 am
JrZook wrote:
8O 8O 8O
Dan
But if you used high tensile bolt's it not your fault.. :roll: :P
Users browsing this forum: No registered users and 352 guests
