It is currently Thu Oct 29, 2026 3:34 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Post Posted: Wed Jun 23, 2010 12:04 am
i have six (6) 50w bulbs that i want to put under my car for rock lights, i dont hve a clue how to set them up, do i run them of several switches and relays or one switch and one relay, i want it set up for, if one light smashes or doesnt work the rest will still work. does any one have any wiring diagrams or no how to set them up. info will be much appreciated as i dont have a clue
Post Posted: Wed Jun 23, 2010 1:22 am
i would go 1 switch and 1 relay if a light blows the others will still work its the same set up as the head lights and you can blow one bulb and still have the other.
Post Posted: Wed Jun 23, 2010 1:46 am
I would drive in the day
Post Posted: Wed Jun 23, 2010 1:49 am
ok thanks so do i put all the negative wires onto the chassis and just run all the positives together and have a negative switch of the relay
Post Posted: Wed Jun 23, 2010 1:51 am
[quote="2stroker"]I would drive in the day[/quote
what??
Post Posted: Wed Jun 23, 2010 1:56 am
I thought it was obvious, if you drive in the day you don't need lights..... sorry I was trying to be funny
Post Posted: Wed Jun 23, 2010 2:00 am
oh silly me, didnt click on bit slow i am sorry mate
Post Posted: Wed Jun 23, 2010 9:47 am
you dont need to negative switch the relay. you can run them all off 1 relay and yes just run the neg. to the chassis. here is ha quick diagram.
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Post Posted: Wed Jun 23, 2010 9:59 am
i have 4 50 or 55w under my hilux but would soon like to go 6 and put 2 in the middle.Just wondering how much is too much off the relay before it becomes a problem?i think its just a 30amp relay.
also plan on throwing 4 under my zuk shortly,they are definately a good thing out night driving
Post Posted: Wed Jun 23, 2010 10:03 am
just go buy a 6 pack of house downlights from the supermarket :lol:
Post Posted: Wed Jun 23, 2010 10:40 am
thats wat i did, they are philip 12v 50w downlights
dominator that helps alot thanks for that :)
Post Posted: Wed Jun 23, 2010 10:47 am
have always looked at them,how you going for mounting them tho??
Post Posted: Wed Jun 23, 2010 10:48 am
get a fuse in there too
Post Posted: Wed Jun 23, 2010 10:56 am
im no auto elecy.You just mean if i pick up power to 30 on my relay from my fuse block at the battery itd be sweet??
what size fuse should people run for this and is there any need to go a bigger relay?can you go bigger than 30A or is it good to have another link to let go ?
Post Posted: Wed Jun 23, 2010 11:04 am
Hey Lewis, make sure you put a fuse between power and the relay as well as between the lights and the relay...
You won't need any more than four rock lights.... You can use the other two as extra reverse lights.
bought the plugs that join to the light the plugs have to screw holes
Post Posted: Wed Jun 23, 2010 11:05 am
hey thnks for that and im Aaron lewis is my mate that got those sit off you
Post Posted: Wed Jun 23, 2010 11:06 am
so do you just throw a inline fuse on output(87) jase???somewhere before first light.Sorry for all the extra questions fellas,just learning a bit more here. :wink:
Post Posted: Wed Jun 23, 2010 11:08 am
yes between lights and another one between battery and relay
Post Posted: Wed Jun 23, 2010 11:12 am
I'm running circuit breakers and I have 8 rock lights on mine. Run off 2 switches pretty bright
Post Posted: Wed Jun 23, 2010 11:13 am
thats alot of light,you got pics man? 8)
Post Posted: Wed Jun 23, 2010 11:17 am
just one of my 50w lights just about lights up the hole underneath of the car, they have a 60 degrees beam so i guess 4 will do me
Post Posted: Wed Jun 23, 2010 11:34 am
my plans for the zuk are one in centre front and back and one each side between F and R.On my hilux tho i have one at each wheel and its a bit black in the centre
do you have pics of your little mounts you were talking about mate.
Post Posted: Wed Jun 23, 2010 11:36 am
Even four X 50W lights is 16.6Amps....... plus headlights, parkers and taillights you are drawing over 30A..... Then there is ignition and trying to charge the battery...
Don't be surprised if you get a flat battery after long night runs....
A 110A EF falcon alt upgrade is recommended.
Post Posted: Wed Jun 23, 2010 11:51 am
I'm running a 60amp alternator. I'm on my phone ATM I'll put some up soon
Post Posted: Wed Jun 23, 2010 11:59 am
they are just a round plug with two screw holes on each side. the two prongs of the light pushes into the plug, while the prongs get clamped in by a spring
Post Posted: Wed Jun 23, 2010 12:02 pm
yea i wanna do the 110 amp alt conversion, bloody friend has 3 falcons but wont part with them
Post Posted: Wed Jun 23, 2010 12:04 pm
I've got 2 100amp alternators left, check the for sale section
Post Posted: Wed Jun 23, 2010 12:18 pm
i was waiting till someone said something like this.
alternative solution is use LED's as they use bugger all power and are bright enough for rock lights. Ask Bruce where he got his as im pretty sure i saw some on casper a while ago. Ebay has a good selection.
Post Posted: Wed Jun 23, 2010 12:23 pm
i was thinking leds to but was going to do the alt conversion ny way
Users browsing this forum: Google [Bot] and 339 guests
