It is currently Fri Oct 30, 2026 11:35 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
Post Posted: Sun Jun 13, 2010 10:16 am
hey hey,
have a bit of a weird one with my RD88 air locker in the front of my vitara, the bastard will not disengage.
any ideas on what would cause it to stay locked, it's been in there for around a year & has never given me a problem, usually it unlocks as soon as the load comes off the drive train.
Post Posted: Sun Jun 13, 2010 10:30 am
been driving a little harder than normal lately?
Post Posted: Sun Jun 13, 2010 10:31 am
ya dont get that problem with a lockright :wink: :thefinger:
Post Posted: Sun Jun 13, 2010 10:38 am
nah, same type of terrain that i usually use it on & only used it when i need it. it had been a couple of weeks since the last time it had been used, used it for spazmotically for a couple of hours, had some lunch when to do some more wheeling & it didn't unlock.
there is the same amount of air being release from the solenoid when hitting the switch, no oil coming up the line & the diff breather is clear.
Vehicle: MY2019 Jimny
Post Posted: Sun Jun 13, 2010 10:59 am
SHould they be used every few weeks? I haven't used mine for a few months...
Post Posted: Sun Jun 13, 2010 11:04 am
regularly i activate it in traffic with the hubs unlocked & in 2wd just to hear that cool pssssst noise
Post Posted: Sun Jun 13, 2010 11:05 am
bit of wind-up keeping it under load? a mate of mine had a similar issue with his truck but as i remember after a few days it sorted itself out :?
The LWB From 1993. Poetry in motion :P
Vehicle: SJ50 hardtop!
Post Posted: Sun Jun 13, 2010 12:43 pm
I think the princess is just a bit upset she hasn't still got her "soft bits" that she was born with anymore.
To fix this, I can swap you my complete front diff with yours, FREE OF CHARGE; you'll just have to pay shipping.
NT SJ50
Post Posted: Mon Jun 14, 2010 12:52 am
My arb air locker did the same. Turns out is was the slighest kink in an airline that restricted the "pssssst".
255 characters
Post Posted: Mon Jun 14, 2010 9:16 am
no kinks in the air line.
sure :finger: :roll:
Post Posted: Mon Jun 14, 2010 9:19 am
it's the front diff, with it in 2wd & the hubs locked & it switched off it still "pushes" like when it's locked, with 1 hub locked & in 4wd it's locked & putting drive to the locked hub when the switch is off.
it's got me stuffed.....
Post Posted: Mon Jun 14, 2010 9:23 am
Do you hear the Pstttt noise from the soleniod/pressure switch fine?
255 characters
Post Posted: Mon Jun 14, 2010 9:27 am
I think bucket is right, it's broken. $20?
:D
Post Posted: Mon Jun 14, 2010 9:28 am
yeah, the psst is the same as it was previously to the no unlock issue.
jack it up, wheels off the ground. ondo the bulk head fitting and see if the wheels will spin opposite. if still no luck you more than likely have a broken piston. i have not come across these very often and usually is a restult of engaging with one wheel spinning more than the other. let me know how you go.
Post Posted: Mon Jun 14, 2010 9:32 am
Joe, should they be activated frequently when not in use?
Post Posted: Mon Jun 14, 2010 9:33 am
thanks joe, i'll give that a shot.
i've never engaged it with wheels spinning, i do have a fair bit of mechanical sympathy :wink:
Post Posted: Mon Jun 14, 2010 9:42 am
no, not really. the main thing to do is engage the front every so often (not 4x4 though) so you don't end up with a rusty 'tide line' on the crown wheel and locker bulk head.
Post Posted: Mon Jun 14, 2010 9:56 am
yeah cool thanks.
Post Posted: Thu Jun 24, 2010 2:56 am
Hmmmm, just did the above test & both wheels spin the same way with the bulkhead fitting removed. 8O
On the weekend I'll drop the oil & go from there!!! :cry:
Post Posted: Thu Jun 24, 2010 2:59 am
i had the same issue with my rear at one point. the little plastic tabs on the piston that hold the gear had snapped off. i suspect that the previous owner has run it with low oil and over heated the plastic.. was a 14 dollar part when i bought one last.
Post Posted: Thu Jun 24, 2010 3:04 am
it was BRAND NEW & has been in there for about 12 months, fitted by a diff specialist!!!! :?
Post Posted: Thu Jun 24, 2010 3:07 am
the piston is plastic, all it would take i would say is to be still slightly rolling when you engage or disengage it and the the tabs could crack off.
Post Posted: Thu Jun 24, 2010 4:14 am
rolling is not the problem, its engaging with both wheels spinning at different speeds. it may be worth doing a warranty claim if the piston is damaged. that way they can see the piston and determine material failure or driver neglect.
Post Posted: Fri Jun 25, 2010 1:55 am
do you think they would kick up a stink seeing i'm running 31's on my vit? :wink:
Post Posted: Fri Jun 25, 2010 9:13 am
dont they cover them up to a 31" tyre.i remember when my dad was having troubles with his mq rear locker.They said take the 33s off and bring it back for warranty :?
Post Posted: Fri Sep 17, 2010 10:42 am
so the legendary air locker has plastic internal parts, bit of a disappointment 8O
parts replaced:
Quad Ring, XR133V75 x 2
part number 160235
Locking Tab 6mm x8
part number 150402
U Ring - RD 75/87/88/118 x 1
part number 160306
Piston, G Type x1
part number 040201
Post Posted: Fri Sep 17, 2010 10:44 am
someone has to say it. :lol:
gee my lockrights are great value for money and work all the time. :wink:
Post Posted: Fri Sep 17, 2010 10:50 am
if it were a steel piston it would be a heap less forgiving. the plastic one actually puts up better with shock loading to a point.
been doing some more digging........seems the piston will do that when engaging the diff with one wheel spinning......or 'crash locking' them going around corners.
Users browsing this forum: No registered users and 414 guests
