| Author |
Message |
93zook
Joined: Wed May 27, 2009 11:30 pm Posts: 699 Location: perth
 Posted: Tue Jun 22, 2010 9:48 am |
hey guys, just wondering if anyone has ever shaved sierra diffs and how much extra clearence you gained?
appsie
 Posted: Tue Jun 22, 2010 10:00 am |
dunno if he was on here but there was a young fella in NZ i think who shaved his sierra diffs.Jazuki i think was his username,had a little red hardtop like yours.
Would be interesting to see how much can be taken off em.
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Tue Jun 22, 2010 10:06 am |
i wouldnt think you could take off more than about 10mm by the time you close it back up?
definitely not something thats commonly done on sierra diffs anyway.
lizzard
Joined: Tue Apr 20, 2010 11:30 pm Posts: 99 Location: sydneyhills.com.au
 Posted: Tue Jun 22, 2010 10:10 am |
God that made me L"OO"K did you say SHAVED
appsie
 Posted: Tue Jun 22, 2010 10:35 am |
hasnt gwagen done some?or a vitara rear shaved?
maybe joeblow?at the end of the day just protect it and drag it
BlueSuzy
 Posted: Tue Jun 22, 2010 10:55 am |
I was considering shaving my lux/bundy diffs. After its welded and done. Most difs leak oil as it seeps past the welds.
I have a welded sump with a sensor. It seeps/leaks
So, in the end, Im not going to shave them.
alien
 Posted: Tue Jun 22, 2010 10:56 am |
BlueSuzy - can't you clean it up and Sikaflex the crap out of the welds to seal it up?? (outside of course).
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Tue Jun 22, 2010 11:00 am |
alien wrote: i wouldnt think you could take off more than about 10mm by the time you close it back up?
You only need 12mm to gain an extra tyre size of diff clearance.
appsie
 Posted: Tue Jun 22, 2010 11:04 am |
its allready zuk diffs on 33s thats pretty impressive clearance.
Surely it can be done without them leaking tho.Grind em out and keep welding.but at the end of the day id probably leave it alone myself too.
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Tue Jun 22, 2010 11:58 am |
no welding should leak/weep oil if you clean it all and weld togther properly.
but if you must a thin smear of sikaflex on the inside would probably stop it, also only if the inside is clean first
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Tue Jun 22, 2010 12:36 pm |
someone say shaved............ahh crap......its just diffs............
_________________ builder of custom road legal zooks......and stuff.
Red89
 Posted: Wed Jun 23, 2010 8:36 am |
appsie wrote: its allready zuk diffs on 33s thats pretty impressive clearance.
The only problem is rocks are very rarely wheel track width and nice and flat, I have roughly the same clearance as Simon and my front diff has some huge dents in it
BenT
Joined: Sun Nov 16, 2008 10:30 pm Posts: 208 Location: Nelson, NZ
Vehicle: 85 SJ413
 Posted: Wed Jun 23, 2010 9:13 am |
I posted this on O*terlimits a while ago:
My shaved diffs give me 300mm on 32" Simex's. Same as Hilux on 35" Simex's
_________________ WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
appsie
 Posted: Wed Jun 23, 2010 9:20 am |
thats pretty cool benT
alien
 Posted: Wed Jun 23, 2010 1:33 pm |
farrrrk thats mega-shaved! its like... bald!
Pubic
 Posted: Thu Jun 24, 2010 1:45 am |
how thick was the material you used to re plate it?
_________________ Web wheeler extroadinaire
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Thu Jun 24, 2010 1:46 am |
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Thu Jun 24, 2010 2:06 am |
Zook_Fan wrote: how do you drain it?
Remove the bottom two bolts that hold the centre in... Would work wouldn't it?
Zook_Fan
 Posted: Thu Jun 24, 2010 3:32 am |
yeah i suppose it would as long as no gasket goo or anything is used when the centre is put in and it would be farking slow
Pubic
 Posted: Thu Jun 24, 2010 4:55 am |
You could put a plug at 7 o'clock relative to the face so you could drive it up a ramp on the passenger side and drain it from the side???
BenT
Vehicle: 85 SJ413
 Posted: Thu Jun 24, 2010 9:22 am |
Pubic wrote: how thick was the material you used to re plate it? 3mm from memory. Tracks are mostly mud over here, so not much risk of caving it in. If I was doing a lot of rock I might go a little thicker, although thats about what the standard housing is anyway. want33s wrote: Zook_Fan wrote: how do you drain it? Remove the bottom two bolts that hold the centre in... Would work wouldn't it?
Yup exactly, just pull the bolts and wait a wee while.
Ben
burls
Joined: Sun Mar 07, 2010 10:30 pm Posts: 989 Location: Ipswich
Vehicle: 95 sj70 and 78 lj81
 Posted: Thu Jun 24, 2010 11:20 am |
cheap lift
got any pics with it assembled??
86slowsierra
Joined: Fri Jul 25, 2008 11:30 pm Posts: 724 Location: Melbourne
Vehicle: nt sierra
 Posted: Fri Jun 25, 2010 5:42 am |
been thinking of this abit. I'd recon it would only be worth it if it was WT diffs. otherwise whats the point?
all that effort and you cant put chromie axles in.
obviously you would want to strengthen it at the same time and probably put a gard on
86slowsierra
Vehicle: nt sierra
 Posted: Fri Jun 25, 2010 5:48 am |
would it be possible to ark weld on the pumpkin . im pretty handy with a stick. i also have a tig but no friggen idea how to use it.
weaves
Joined: Fri Mar 21, 2008 10:30 pm Posts: 1564 Location: Newcastle
 Posted: Fri Jun 25, 2010 6:26 am |
BlueSuzy wrote: I was considering shaving my lux/bundy diffs. After its welded and done. Most difs leak oil as it seeps past the welds.
Use Loctite 290 - super wick in.
the stuff is like water, fills all the pin holes and sets. We have a customer who buys it for some diesel/petrol tanks he makes.
Just run it along your welds once they have cooled.
weaves
_________________ I'm Weaver & i like beer, boobs, cars and stickers
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13015 Location: Melbourne
 Posted: Fri Jun 25, 2010 7:19 am |
I've done a few. They do require good preparation and care when welding to prevent leaks.
Also, I've always welded mine with a diff centre bolted in. You'd be surprised how far they pull when you're welding them back together.
Is there a point to all the work? For sure. not only is there a gain in clearance, the shape of the bottom of the housing can be improved a lot, helping the housing to slide rather than catch.
It's quite a lot of work though. I have a jig to try and keep the axle straight. It also assists in measurements when you are cutting.
WT front. I didn't do the cut, but I welded it up. This doesn't have a drain, so it's a "pull a couple of bolts" drainer.
My Vitara rear. Vitaras use studs not bolts on the rear housing, so you have to fit a drain.
CJ!'s Vitara rear. We built a new cover at the same time on his diff.
My Jig. It's 6mm wall thickness and fawking heavy. It's designed for building the cut down full floating vitara rear diffs we are running.
here's some photos of the MQ rear we shaved for Critta. This car also had countersunk high clearance spring pads/plates
and in this (at the time, unfinished) shot, you can see that clearance is pretty good, even with only 36's on an MQ diff.
In Vic, we are regularly dragging our diffs with sierra axles and over 35" tyres. Every bit we can gain is worth pursuing.
appsie
 Posted: Fri Jun 25, 2010 9:04 am |
cool steve
Whats the reasoning for the pinion angle like that on the mq rear??Also are the ubolt setup on the diff like that reasonably strong?cheers
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Fri Jun 25, 2010 9:13 am |
Hey Gwagensteve please can we see some more pics of your zook
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
Gwagensteve
 Posted: Fri Jun 25, 2010 9:58 pm |
appsie wrote: Whats the reasoning for the pinion angle like that on the mq rear??Also are the ubolt setup on the diff like that reasonably strong?cheers
The pinion angle was done like that to increase clearance. You'll notice that driveshaft has a double cardan joint on it at the diff end. We rolled the pinion up until the nose of the diff was level with the transfer so all the angle was on the double cardan joint. It was a kind of cheapskate high pinion.
The U bolt elimination plates were fine. Whilst the car didn't do many km's after they were done, it did get pushed very hard. They never showed any signs of trouble.
You'll note looking at the silver car that we have made provision for a similar setup (but improved as the plates wrap right around the axlehousing) to eliminate the stock spring plates which are anchors for us.
joseph - I did start writing up a post for the members thread. I promise over the next week or so I'll try to complete it and post up my photos.
Joe
 Posted: Sat Jun 26, 2010 12:18 am |
Gwagensteve wrote: appsie wrote: Whats the reasoning for the pinion angle like that on the mq rear??Also are the ubolt setup on the diff like that reasonably strong?cheers
The pinion angle was done like that to increase clearance. You'll notice that driveshaft has a double cardan joint on it at the diff end. We rolled the pinion up until the nose of the diff was level with the transfer so all the angle was on the double cardan joint. It was a kind of cheapskate high pinion. The U bolt elimination plates were fine. Whilst the car didn't do many km's after they were done, it did get pushed very hard. They never showed any signs of trouble. You'll note looking at the silver car that we have made provision for a similar setup (but improved as the plates wrap right around the axlehousing) to eliminate the stock spring plates which are anchors for us. joseph - I did start writing up a post for the members thread. I promise over the next week or so I'll try to complete it and post up my photos. Steve.
