It is currently Thu Oct 29, 2026 5:25 am
Post Posted: Wed Jun 23, 2010 10:47 pm
guys trying to get my choke working as it has not for some time now nd is a pain in the mornings atm to get warm.
i read a post by royce explaining how to do it below is ROYCE post can anyone by using the pictures also posted explain via text and pictures how to do this step by step as im a retard! bolded is the things im most confused about
if you can use ms paint or something highlighted where things are it would be sweet.
"ok to set the choke
STEP 1 with engine cold and the intake hat off, the flap should be closed, look at the little gear type linkage on the side that actuates it and you will see 2 lines, they should line up,
STEP 2 if not the tension is wrong, to set that look round the back/side of the carb where the water hoses connect and you will see a screw sticking out of a cylindrical chamber, turn that till they line up, now the amount of choke and time it stays on should be right
STEP 3 next the fast idle speed, have a good look at the throttle linkage and down out of the way youll see a screw you cant get at unless you are holding the throttle full open, thats the fast idle, to set hold the throttle open and screw it in a bit, let it go and start it up and see, I guess you want 1000-1200 rpm.
Top:
Bottom:
Rear:
Front:
Drivers side:
Passenger side:
Image[/quote]
Post Posted: Thu Jun 24, 2010 2:33 am
Pfft, what does Royce know?? You make it sound like he is some Suzuki god :roll:
Post Posted: Thu Jun 24, 2010 5:19 am
his advice has helped in the past
if you can help please do
Post Posted: Thu Jun 24, 2010 6:51 am
But you asked for ROYCE. :roll:
I'd feel 2nd best.. :cry:
Post Posted: Thu Jun 24, 2010 7:19 am
You're alot further down the line than 2nd chump!!! :P :D
Post Posted: Thu Jun 24, 2010 8:05 am
easy
Post Posted: Thu Jun 24, 2010 10:27 am
Thanks I ended up cracking the shits and broke some parts on it so now it's rooted so got another one coming ;( bloody angry red heads
Post Posted: Thu Jun 24, 2010 10:34 am
On pic 3.jpg what is the lever arm with the spring onthe left hand side it moves up when you accelerate
I broke the linkage down at the bottom car appears to run but not sure what that does as it's now hanging loose
Post Posted: Thu Jun 24, 2010 11:51 am
That pushes a plunger that squirts a little fuel into the top of the carby when you open the throttle.
How the hell did you break that?
 Profile WWW ICQ YIM
Post Posted: Thu Jun 24, 2010 12:44 pm
I have red hair and got angry enough said!
So is it needed? Any concern of driving without it
Post Posted: Thu Jun 24, 2010 1:37 pm
Cade wrote:
Thanks;( bloody angry red heads)
Ooh, that's not nice! First he asks for Royce's help and then, when he get's it, he slags off at his Avatar!
[quote="cade']I have red hair and got angry enough said!
[/quote]
Ahh, I see now!
Post Posted: Thu Jun 24, 2010 8:37 pm
yeah when you put your foot down nothing will happen for a few seconds
Post Posted: Thu Jun 24, 2010 10:38 pm
yep found that out this morning try to start it :( pain in the arse
i had to pop the bonnet and manually lift the plunger took for ever to get up and going
Users browsing this forum: Google [Bot] and 336 guests
