It is currently Thu Oct 29, 2026 4:05 pm
Post Posted: Sun Jun 27, 2010 9:00 am
Does anyone have any clear cut ways of telling if the front axle is bent?
The swivel hubs arent leaking or weeping but when i look at the passenger side wheel it looks to me like the bottom sits in a tad further?
There is also more wear on the outside edge of the tyre, however the tyres are quite old and down to about 10% and will be needing a new set soon.
Should also mention it drives fine. But if it was bent would there anything noticable when driving?
Post Posted: Sun Jun 27, 2010 9:07 am
wheel alignment will tell you if your camber is out
Post Posted: Sun Jun 27, 2010 9:12 am
They don't normally bend in at the bottom - normally it's the other way.
Maybe you have shot kingpin bearings or something?
Post Posted: Sun Jun 27, 2010 9:14 am
king pin's is my guess... and what steve said :D
Post Posted: Sun Jun 27, 2010 9:17 am
i may be gettin worked up overnothing.
but then the tyre tread had me lil worried...
here is a pic so you can judge yourselves...
Post Posted: Sun Jun 27, 2010 9:24 am
Just jump it a bit in the dunes. That'll straighten it up :D
Post Posted: Sun Jun 27, 2010 9:36 am
anyway of telling if its the kingpins without gettin an alignment done??
I dont have the time to take into get an alignment mob as I'm so flat out with work, start early finish late plus I'm planning on getting one in a couple of months once I put the lift in, let it settle then get some new tyres
Post Posted: Sun Jun 27, 2010 9:43 am
jack up under diff, wobble wheel top and bottom, if it moves theres something wrong
Post Posted: Sun Jun 27, 2010 9:55 am
ok thanks royce,
will give that a go..
Post Posted: Sun Jun 27, 2010 10:06 am
any strange sounds??? collapsed wheel bearing would do that too - but you'll find you chew out the brakes pretty fast too.
as for a way to check if its out of camber, a real basic test is get a mate on the other side of the car, and between the 2 of you, measure point to point around your rims (from the inside). you should get the same measurement all the way around (near enough).
Post Posted: Sun Jun 27, 2010 10:19 am
nice...thanks alien, i like that one too, i'll give that a go
Users browsing this forum: Google [Bot] and 274 guests
